13
I have a zip which contains files with very long names.
If I try to extract on the command line, I get the error "File name too long".
If I use the graphical archive manager it will not extract the files and it will not let me rename them. The same problem occurs if I mount the archive.
I can extract and rename files individually using:
unzip -p -c example.zip "long file name.ogg" > shortname.ogg
This is impractical with lots of files.
Is there a tool which will truncate filenames as they are extracted?
Ravexina
  • 57,256
Terence Eden
  • 1,826
To extract
We can use zipinfo as a part of this process, it's a program from zip package.
zipinfo -2 example.zip
will only shows the files names in example.zip, something look like:
file1-long-name-...-bla-bla.html
file2-long-name-...-bla-bla.html
so we can use this feature to extract all files:
zipinfo -2 example.zip | while read i;
do
  long_fname=${i%.*}
  unzip -p -c example.zip "$i" > "${long_fname:0:250}.${i##*.}"
done;
  • long_fname=${i%.*}: Removes extension from long file name, so in case of file name being less that of 256 character; We're not going to get a duplicate extension.
  • ${long_fname:0:250}.${i##*.}: Creates a new file name with legitimate number of character also adds a . and file real extension.
Simply we are looping into files list and extract each of them with a new legitimate file name which is 256 character.
To rename
You can use zipnote command, it's a part of zip package too.
Get a backup of your zip file first.
Run this command:
zipnote example.zip > names
Open names using an editor, it's look like this:
@ file name long in zip and a lot of other strings in the file name
@ (comment above this line)
@ (zip file comment below this line)
Add new file names like this:
@=new short name for above file
Then to rename files use:
zipnote -w example.zip < names
You renamed them all, you can also write a simple script which do this automatically for you.
Ravexina
  • 57,256
The other answer didn't work for me for some reason, even after decreasing the output file name to length 100, so instead I just extracted all files at once with unzip -p > all.txt and then split the file all.txt with csplit based on some pattern.
Note that unzip will add lines like
------=_Part_4952_1005066427.1638023175221
and
    boundary="----=_Part_4953_1221949914.1638023175221"
which should be removed from the output and probably used to split the file, but I didn't need to do that so how to do this properly is left as an exercise :)
Metaxal
  • 403
Here is the version that handles long directory names as well. You can add it as a function to your ~/.bashrc or wherever you store your functions or aliases.
unziplong() {
    max_base_len=100
    max_ext_len=15
    zipinfo -1 "$1" | grep -v "/$" | while read orig_path
    do
        new_path=""
        current_path="$orig_path"
        while [[ "$current_path" != "." ]]
        do
            segment="$(basename -- "$current_path")"
            ext="$([[ "$segment" =~ .*\..{1,$max_ext_len}$ ]] && echo ".${segment##*.}" || echo)"
            base="${segment%$ext}"
            segment="/$(xargs <<< "${base:0:$max_base_len}")$(xargs <<< "$ext")"
            new_path="$segment$new_path"
            current_path="$(dirname -- "$current_path")"
        done
        new_path="${new_path:1}"
        new_dir="$(dirname -- "$new_path")"
        mkdir -p "$new_dir"
        unzip -p "$1" "$orig_path" > "$new_path"
    done
Igor Mikushkin
  • 345
