At first I had my firewall set up like this:
└─$  sudo iptables -L
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     udp  --  anywhere             anywhere             udp dpt:domain
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:domain
ACCEPT     udp  --  anywhere             anywhere             udp dpt:bootps
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:bootps
Chain FORWARD (policy ACCEPT)
ACCEPT     all  --  anywhere             192.168.122.0/24     ctstate RELATED,ESTABLISHED
ACCEPT     all  --  192.168.122.0/24     anywhere
ACCEPT     all  --  anywhere             anywhere
REJECT     all  --  anywhere             anywhere             reject-with icmp-port-unreachable
Chain OUTPUT (policy ACCEPT)
ACCEPT     udp  --  anywhere             anywhere             udp dpt:bootpc
But then I enabled ufw (with a port open I think) and then this abomination happened:
Chain INPUT (policy DROP)
ufw-before-logging-input  all  --  anywhere             anywhere
ufw-before-input  all  --  anywhere             anywhere
ufw-after-input  all  --  anywhere             anywhere
ufw-after-logging-input  all  --  anywhere             anywhere
ufw-reject-input  all  --  anywhere             anywhere
ufw-track-input  all  --  anywhere             anywhere
Chain FORWARD (policy DROP)
ufw-before-logging-forward  all  --  anywhere             anywhere
ufw-before-forward  all  --  anywhere             anywhere
ufw-after-forward  all  --  anywhere             anywhere
ufw-after-logging-forward  all  --  anywhere             anywhere
ufw-reject-forward  all  --  anywhere             anywhere
ufw-track-forward  all  --  anywhere             anywhere
ufw-before-logging-output  all  --  anywhere             anywhere
ufw-before-output  all  --  anywhere             anywhere
ufw-after-output  all  --  anywhere             anywhere
ufw-after-logging-output  all  --  anywhere             anywhere
ufw-reject-output  all  --  anywhere             anywhere
ufw-track-output  all  --  anywhere             anywhere
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:netbios-ns
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:netbios-dgm
ufw-skip-to-policy-input  tcp  --  anywhere             anywhere             tcp dpt:netbios-ssn
ufw-skip-to-policy-input  tcp  --  anywhere             anywhere             tcp dpt:microsoft-ds
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:bootps
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:bootpc
ufw-skip-to-policy-input  all  --  anywhere             anywhere             ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ACCEPT     all  --  anywhere             anywhere             ctstate RELATED,ESTABLISHED
ACCEPT     icmp --  anywhere             anywhere             icmp destination-unreachable
ACCEPT     icmp --  anywhere             anywhere             icmp source-quench
ACCEPT     icmp --  anywhere             anywhere             icmp time-exceeded
ACCEPT     icmp --  anywhere             anywhere             icmp parameter-problem
ACCEPT     icmp --  anywhere             anywhere             icmp echo-request
ufw-user-forward  all  --  anywhere             anywhere
Chain ufw-before-input (1 references)
ufw-logging-deny  all  --  anywhere             anywhere             ctstate INVALID
DROP       all  --  anywhere             anywhere             ctstate INVALID
ACCEPT     udp  --  anywhere             anywhere             udp spt:bootps dpt:bootpc
ufw-not-local  all  --  anywhere             anywhere
ACCEPT     udp  --  anywhere             224.0.0.251          udp dpt:mdns
ACCEPT     udp  --  anywhere             239.255.255.250      udp dpt:1900
ufw-user-input  all  --  anywhere             anywhere
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output  all  --  anywhere             anywhere
Chain ufw-logging-allow (0 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 10 LOG level warning prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN     all  --  anywhere             anywhere             ctstate INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type LOCAL
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type MULTICAST
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type BROADCAST
ufw-logging-deny  all  --  anywhere             anywhere             limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT     tcp  --  anywhere             anywhere             ctstate NEW
ACCEPT     udp  --  anywhere             anywhere             ctstate NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:9001
ACCEPT     udp  --  anywhere             anywhere             udp dpt:9001
Chain ufw-user-limit (0 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 5 LOG level warning prefix "[UFW LIMIT BLOCK] "
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
This is really obtuse! I am just learning iptables and this made it much more confusing.
So then I disabled ufw, but the rules still stayed:
I even tried resetting ufw rules as per this answer, but iptables -L output stayed the same.
So how can I totally get rid of all ufw entries in iptables list?
To delete all rules and chains run this command.
 sudo iptables --flush
 sudo iptables --delete-chain
2707974
  • 10,758
Two ways this can be done:
Method 1
  1. Run sudo ufw status numbered:
          To                         Action      From
    [ 1] 1433                       ALLOW IN    Anywhere
    [ 2] OpenSSH                    ALLOW IN    Anywhere
    [ 3] Anywhere                   DENY IN     78.140.181.188
    [ 4] Anywhere                   DENY IN     78.140.181.169
    [ 5] 78.140.181.169             DENY OUT    Anywhere                   (out)
    [ 6] 78.140.181.169             DENY IN     Anywhere
    [ 7] 78.140.181.188             DENY IN     Anywhere
    [ 8] 78.140.181.188             DENY OUT    Anywhere                   (out)
    [ 9] 216.21.13.17               DENY IN     Anywhere
    [10] 216.21.13.17               DENY OUT    Anywhere                   (out)
    [11] 104.17.30.15               DENY IN     Anywhere
    [12] 104.17.30.15               DENY OUT    Anywhere                   (out)
    [13] 167.153.201.138            DENY OUT    Anywhere                   (out)
    [14] 167.153.201.138            DENY IN     Anywhere
    [15] 78.140.188.186             DENY IN     Anywhere
    [16] 78.140.188.186             DENY OUT    Anywhere                   (out)
    [17] 3478/udp                   ALLOW IN    Anywhere
    [18] 3478/tcp                   ALLOW IN    Anywhere
    [19] 1433 (v6)                  ALLOW IN    Anywhere (v6)
    [20] OpenSSH (v6)               ALLOW IN    Anywhere (v6)
    [21] 3478/udp (v6)              ALLOW IN    Anywhere (v6)
    [22] 3478/tcp (v6)              ALLOW IN    Anywhere (v6)
  2. Delete each with sudo ufw delete [number]
Method 2
  1. To take the rules back to the default settings:
    sudo ufw reset
Note:
If you want to see how the sudo ufw reset will change your rules use --dry-run option first, then compare the /etc/ufw/before.rules.20170513_185835 file to the /etc/ufw/before.rules.20170513_185835 file.
Example:
sudo ufw --dry-run reset
To compare:
sudo diff /etc/ufw/after.rules.20170513_185835 /etc/ufw/before.rules.20170513_185835
George Udosen
  • 37,534
