(x-posted from StackOverflow)
I have set up cron to execute the following command for django-cron (django 1.10.5, python 3.5, anaconda 4.2.0) in ubuntu 16.04:
PATH=/user/project/projectname/website
* * * * * ./manage.py runcrons "app.crons.RunCronJob"
Here is my file tree, which is located directly under the highest level of the remote site (/):
|-- user
| |-- project
| | |-- projectname
| | | |-- website
| | | | |-- file.txt
| | | | |-- manage.py
| | | | |-- app (a django app)
| | | | | |-- crons.py
RunCronJob is a cronjob within crons.py that appends a line to file.txt under /website. When I enter the /website directory and manually do ./manage.py runcrons "app.crons.RunCronJob", it works just fine. However, when the cronjob I have set up is run, it does not append anything to my text file. I have verified that the cron task is running every minute with both grep cron /var/log/syslog a mailing service, but the data I receive doesn't seem to tell me anything useful about why it isn't working.
(Note for python: I have added os.chdir(os.path.dirname(sys.argv[0])) to the top of my crons.py to ensure that the text file gets written to in the correct directory, no matter where the command is run from. E.g., running website/manage.py runcrons "app.crons.RunCronJob" from /projectname is working for me as well. For this reason, I don't suspect my issue is related to django, the django-cron library or python.)
I have viewed some other answers which discuss some common problems with cron and have tried my best to fix any problems: my crontab has a newline at the end, I have set my timezone (though this should not affect my cronjob), pgrep cron returns a number, I have set the permissions for my text file, I have restarted cron many times, etc.
Although I have also tried to properly set my environment paths, I suspect that some part of it is still wrong. I tried various things like adding /home in front of /user, removing the dot and/or slash in front of manage.py, and adding the absolute filepath in front of my command, all to no avail.
Even though I think my suspect is in how I am setting my paths, the error could still be somewhere else in my project. What issue am I overlooking, or how should I diagnose it?
