I have a problem with installation of apps from the terminal. These are examples of this problem:
ratanak@ratanak-walker:~$ sudo apt-get install httrack
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
httrack : Depends: libhttrack2 (>= 3.48.24) but it is not going to be installed
rstudio : Depends: libjpeg62 but it is not going to be installed
Depends: libgstreamer0.10-0 but it is not installable
Depends: libgstreamer-plugins-base0.10-0 but it is not installable
Recommends: r-base (>= 2.11.1) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
ratanak@ratanak-walker:~$ sudo apt-get install r-base
r-base : Depends: r-base-core (>= 3.4.0-1xenial0) but it is not going to be installed
Depends: r-recommended (= 3.4.0-1xenial0) but it is not going to be installed
Recommends: r-base-html but it is not going to be installed
Recommends: r-doc-html but it is not going to be installed
I notice that these problem started when I started installing program r.
