I'd love to play Diablo 1 on Ubuntu.
How can I do that?
Zanna
  • 72,312
Oxana Ushakova
  • 161
You can do it easily. Install wine and PlayOnLinux. Download the game, and use the Miscellaneous tab of playonlinux to run the exe.
The process could be as follows:
  1. Install playonlinux:
    sudo apt-get install playonlinux
If the program can't be found in your software sources, download from here: PlayOnLinux
  1. Install wine:
    sudo apt install wine
  2. Download the game
  3. On PlayOnLinux, go to Configure -> General tab
  4. In the left side panel, click on New, to create a new virtual disk.
  5. Select the new created disk, and go to the Miscellaneous tab.
  6. Click on Run a .exe in this virtual drive, and select the diablo installer.
  7. Follow the installation program, and install it normally.
  8. Once finished, go to the General tab, and click on Make a new shortcut for this virtual drive. Follow the instructions and search for the diablo executable.
  9. Finish and close the Configuration window.
  10. The diablo shortcut should appear in the main screen of PlayOnLinux, select it and click on Run.
GTRONICK
  • 4,344
some other solutions:
  • install virtualbox - free https://www.virtualbox.org/ or vmware player http://www.vmware.com/
  • create a virtual xp machine, tutorials youtube https://www.youtube.com/watch?v=rJt6scJyDUw
  • install xp guest additions with 3d support from safemode https://www.youtube.com/watch?v=9EMvQqBCBqY
  • install game
  • hf
be advised.. the mouse jumps uncontrollably sometimes especially if you scale the guest window; as a solution disable mouse integration and attach the mouse to virtual machine(you will be unable to take it outside of vm unless you disconnect it from the socket.. usb mouse)
  • is helpful to have 2 mouses one attached to vm the other for host
edit: regarding vinehq.. be careful of infected programs.. thay can run as in windows and you cant jail windows apps to vinehq folder
obs: for vmware player.. youtube for tutorials.. i dont use it on linux as i prefer gpl/free/apt-repo programs; performance wise is close to virtualbox; i play lod/quake2/starcraft on virtualbox.. very fluent only problem is mouse bugs.. see workaround
