I only see tutorials for installing Ubuntu on a Chromebook with crouton, but I want fully working Ubuntu!
Is it possible to Install Ubuntu on a Chromebook without crouton?
Asked
Active
Viewed 2.7k times
To install a full Linux distribution on your chromebook you have multiple choices. You can use chrx to make a dual boot. Or you can install directly a full version of Ubuntu (best to go for LUbuntu or Xubuntu).
I would recommend to install GalliumOS as it is derived from XUbuntu and it's optimized for chromebooks.
To do this, you should follow GalliumOS installation steps:
- First, you have to enable developer mode on your chromebook (and remove all data on your disk).
- Second, you have to update your firmware to be able to boot on a USB key.
- Third, install your Ubuntu/Gallium, or a dual boot using chrx.
Step one and two are really well documented on GalliumOS's wiki, you will find all your answers here.
XGuenard
- 21
