I used to access files by typing \\\fileserver2 in run command in windows. How do I access them in Xubuntu 16.04 LTS?
I tried using ftp://fileserver2 in terminal but it said there is no such directory.
I am new to Linux so I have no idea. I followed the answer to "Access to network files under \\directory" but it didn't work.
Zanna
  • 72,312
Mahima
  • 13
If you want to mount your FTP server so you can access it via GUI, do the following (this is probably the most convenient solution):
Install curlftpfs. Open a terminal and type:
sudo apt-get install curlftpfs
Create the directory you want to mount your FTP server to, for example
mkdir /home/username/fileserver2
Then mount it with
curlftpfs username:password@fileserver2 /path/to/your/created/folder -o allow_other,disable_eprt
Or if you want a SSL/TLS encrypted connection
curlftpfs username:password@fileserver2 /path/to/your/created/folder -o allow_other,disable_eprt,tlsv1
If you dont need it anymore, use
fusermount -u /path/to/your/created/folder
to unmount it.
Alternatives:
  • Use a FTP client like FileZilla
  • Use the terminal: sudo apt-get install ftp and then ftp servername. To learn how to use it look at the manpage via man ftp
