I get this error:
sudo dpkg --force-all -i teamviewer_12.0.76279_amd64.deb
[sudo] password for elvis:
Selecting previously unselected package teamviewer.
(Reading database ... 121496 files and directories currently installed.)
Preparing to unpack teamviewer_12.0.76279_amd64.deb ...
Unpacking teamviewer (12.0.76279) ...
dpkg: teamviewer: dependency problems, but configuring anyway as you requested:
 teamviewer depends on libc6-i386 (>= 2.11); however:
  Package libc6-i386 is not installed.
 teamviewer depends on lib32asound2; however:
  Package lib32asound2 is not installed.
 teamviewer depends on lib32z1; however:
  Package lib32z1 is not installed.
 teamviewer depends on ia32-libs; however:
  Package ia32-libs is not installed.
Setting up teamviewer (12.0.76279) ...
Job for teamviewerd.service failed because the control process exited with error code. See "systemctl status teamviewerd.service" and "journalctl -xe" for details.
Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu5.1) ...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
sudo dpkg --force-all -i teamviewer_12.0.76279_amd64.deb  4.82s user 0.36s system 58% cpu 8.835 total
What can I do to install it?
lewis4u
  • 5,046
I have found an answer for this problem here.
There is an official package at teamviewer website and you can get it like this:
wget http://download.teamviewer.com/download/teamviewer_i386.deb
it works for x64 bit ubuntu!!
This package is somehow different and just let's you to install it.
Just download it and run sudo dpkg -i teamviewer_i386.deb
update
this works also for x64 version of ubuntu!
and sometimes the teamviewer wont show the ID number and password, then you need to restart the teamviewer daemon with this command:
sudo teamviewer --daemon restart
and then start the teamviewer again
lewis4u
  • 5,046
