This looks a neat programme for managing cryptocurrency on Linux
I've been using Ubuntu for 3 or 4 years, used the terminal parrot fashion for various functions and installs, but have v. little knowledge.
Does anyone think this would run on Ubuntu and if so, how could I install it?
Or is there a better solution?
Thanks
Zanna
  • 72,312
Exodus co-founder here... You can place the folder wherever you like. We recommend just dropping it in your home directory. You can then run Exodus by just double-clicking on the Exodus program or by running it directly from the terminal: ./Exodus.
Long-term, we'll probably offer a .deb so that it can easily be installed in the proper location. Also, note that it'll only run on 64-bit Linux.
This'll cover you for install (and update if you Cron as discussed above)... Wanted to add this as a reply to @JP Richards, but I'm not with enough reps yet (help a brother out, guys) :)
https://github.com/robotard/ExodusUpdater/
Grab the exodus.sh file, and 'sudo ./exodus.sh'...
It will always check if you have the latest or any version installed, and download and install the most recent .deb :)
