tl;dr
How do I get vlc working with nvidia-375 and Xenial (16.04)?
Context
On April 10 2017, apt, via the x-org-edgers PPA updated my nvidia drivers from nvidia-367 to nvidia-375.
Shortly after vlc stopped working.
I uninstalled and tried to reinstall vlc, but got this:
vlc : Depends: libgles1-mesa (>= 7.8.1) but it is not going to be installed or
libgles1
Question
- How do I get VLC working again?
- How should I set up my ppa so that once nvidia/display it does not update it? (i.e. remove the ppa file from /etc/apt/sources.list.d )
A few points
- I probably should not have the 'x-org edgers' PPA but i moved my settings from a prior laptop where some display features did not work
I don't do anything fancy graphics-wise (gaming, etc): just drive a 4K display and want suspend/resume to work correctly
I've tried reverting to nvidia-367, but that did not seem to fix the problem. (Nor am I sure it installed correctly).
thanks
Update #1
I ran ppa purge for xorg-edgers and installed nvidia-current drivers:
$ sudo ppa-purge ppa:xorg-edgers/ppa
$ sudo apt-get install nvidia-current
$ sudo apt-get autoremove
Update #2
Here is policy for libgles1-mesa as well as output of install nvidia-current
$ sudo apt-cache policy libgles1-mesa libgles1-mesa:
Installed: (none)
Candidate: 12.0.6-0ubuntu0.16.04.1
Version table:
12.0.6-0ubuntu0.16.04.1 500
500 http://us.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
11.2.0-1ubuntu2 500
500 http://us.archive.ubuntu.com/ubuntu xenial/main amd64
Packages
Reading package lists... Done
Building dependency tree
nvidia-current is already the newest version (304.135-0ubuntu0.16.04.1).
0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
Update #3: output of "apt-get install vlc"
$sudo apt-get install vlc
Building dependency tree...
Reading state information...
libgles1
