I have Qt 5.7.
I need Qt 5.6.
Can I revert my currently installed version back to 5.6, or can I install 5.6 beside it using apt/the repos? Or will I have use the Qt installer?
This is for compiling software to be run on a remote server which does not yet have 5.7.
Anon
  • 12,339
https://download.qt.io/archive/qt/5.6/5.6.2/
Set the downloader as executable, run it, choose a directory, and from QtCreator, goto the options and set the qt version manually.
Anon
  • 12,339
you can unistall it with Synaptic package manager in Ubuntu and install new version in it in Synaptic you tick Qt or you can use apt-get
sudo apt-get remove yourpackagename
With below command you can remove package but keep configuration file.
sudo apt-get remove package_name
if you want to remove configuration file and remove package use:
sudo apt-get purge package_name
for install use:
sudo apt-get install package_name
m-tech
  • 823
