What is the default password for the ejabberd user created on your system when installed from the repository? I'm running Xenial Xereus 16.04.
For clarity's sake, I want to run ejabberdctl without using sudo as root.
For the username, check the ejabberd.yml file in the conf directory under your ejabberd installation directory, usually /opt/ejabberd/. Default username is admin@<your_system_hostname> Default password is admin.
It seems like the username is added to your system without a password given. I just had my admin change the password as root.
