If I open a terminal and run this in the terminal: source /home/deploy/script.sh
It will execute script.sh
command below is what i wrote in script.sh
cd /var/www/applikasi-siao/iClockServer && thin -e production -p 2345 -P tmp/pids/thin.pid -l logs/thin/log start
this command above must run in the same terminal and the terminal should stay open.
I created script.sh so when i open terminal and type source /home/deploy/script.sh it will run
I need all of this processes run automatically every reboot without manually opening a terminal and typing source /home/deploy/script.sh
d a i s y
  • 5,551
Cron/Cronjobs will allow you to automate the task above to after every restart HOWEVER, it won't leave a terminal window open.
For info on Cron you can look at the CronHowto: https://help.ubuntu.com/community/CronHowto
Also please mention what operating system you are using.
Crons are really quite interesting so I highly recommend reading into them but TLDR.
Open a terminal window.
Install Cron
sudo apt-get install gnome-schedule
After that has completed type
crontab -e
If the script requires administrative privileges use:
sudo crontab -e
And then at the bottom of the file add the following with the path being to where that script is.
@reboot /home/username/start_application.sh
Robby1212
  • 910
  • 28
