I have to upgrade Ubuntu server 10.04 to 12.04.
10.04 is not supported any more. So what step I have to do, for a clean upgrade?
I did the following steps:
sudo sed -i -re 's/([a-z]{2}\.)?archive.ubuntu.com|security.ubuntu.com/old-r‌​eleases.ubuntu.com/g‌​' /etc/apt/sources.list
sudo apt-get update && sudo apt-get dist-upgrade
sudo apt-get update
sudo do-release-upgrade
After some time, the upgrade is aborting: ...Restoring original system state
root@vupapzimbra01:~# sudo apt-get install update-manager-core
Reading package lists... Done
Building dependency tree
update-manager-core is already the newest version.
The following packages were automatically installed and are no longer required:
  linux-headers-2.6.32-41-server linux-headers-2.6.32-41
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@vupapzimbra01:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 10.04.4 LTS
Release:        10.04
Codename:       lucid
Get:51 http://us.archive.ubuntu.com precise/restricted Translation-en [2395 B]
Get:52 http://us.archive.ubuntu.com precise/universe Translation-en [3341 kB]
Fetched 19.9 MB in 6s (1873 kB/s)
Checking package manager
Building data structures... Done
Calculating the changes
Error authenticating some packages
It was not possible to authenticate some packages. This may be a
transient network problem. You may want to try again later. See below
for a list of unauthenticated packages.
accountsservice
apparmor
wpasupplicant
xkb-data
Aborting
=== Command detached from window (Thu May  4 09:20:53 2017) ===
=== Command terminated with exit status 1 (Thu May  4 09:20:53 2017) ===
Melebius
  • 11,750
its better to download iso and re install you could install 12.04 Ubuntu server Click link 32 bit or 64 bit you could select the upgrade is not possible for old versions or try 17.04 Click torrent link
