I have connected an SD card to my notebook and I'm using it as my home partition. When I turn my computer on I have no problem reaching the home folder and subdirectories, but when I suspend it and resume, the system doesn't read the SD card. So it may freeze, forcing me to reboot the machine to get everything to work again.
Some useful info is:
- MacBook Air 2016
- macOS Sierra & Ubuntu 17.04 Dual boot
- (Same problem also occurred on 16.10)
Some further info:
$ sudo LC_MESSAGES=POSIX lshw -c storage
*-usb
description: Mass storage device
product: Card Reader
vendor: Apple
physical id: 3
bus info: usb@2:3
logical name: scsi1
version: 8.20
serial: 000000000820
capabilities: usb-3.00 scsi emulated scsi-host
configuration: driver=usb-storage maxpower=896mA speed=5000Mbit/s
$ lsusb -vd 05ac:8406 is:
Bus 002 Device 002: ID 05ac:8406 Apple, Inc.
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x05ac Apple, Inc.
idProduct 0x8406
bcdDevice 8.20
iManufacturer 3
iProduct 4
iSerial 5
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 44
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 224mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 0
bMaxBurst 4
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bMaxBurst 4
Also the main difference is that before suspend lsblk shows my sdb1 device (which is my SD card mounted as /home). After wake-up lsblk command doesn't show my SD card and I can't reach my files on /home folder. Also I can't reconnect my SD card; it isn't recognized.
syslog – the most recent suspension happens from "May 9 22:56:01" at line 45263.
The interesting parts appear to be:
May 9 22:56:25 MacBookAir kernel: [ 5883.035573] PM: Finishing wakeup. May 9 22:56:25 MacBookAir kernel: [ 5883.035575] Restarting tasks ... May 9 22:56:25 MacBookAir kernel: [ 5883.035795] usb 2-3: USB disconnect, device number 2 [...snip...] May 9 22:56:26 MacBookAir kernel: [ 5884.869838] usb usb2-port3: cannot disable (err = -32) May 9 22:56:26 MacBookAir kernel: [ 5884.869942] xhci_hcd 0000:00:14.0: Cannot set link state. May 9 22:56:26 MacBookAir kernel: [ 5884.869969] usb usb2-port3: cannot disable (err = -32)
