I am using Ubuntu 16.04 64-bit. I was trying to uninstall VirtualBox, but I got a lot of errors which ended with a warning telling me that my Software Centre has failed. I restarted the system and was going to try again. I ran: apt-get update and apt-get upgrade before trying anything else.
When I ran the upgrade command, the VirtualBox automatically got installed along with it, but after throwing a lot of warnings at me (I don't remember exactly what those were).
I think I should uninstall this and start fresh but when I try to uninstall using apt-get remove virtualbox* --purge, I got these results:
ananthan@ananthan-X556UQK~$ sudo apt-get remove virtualbox* --purge
Reading package lists... Done
Building dependency tree
Note, selecting 'virtualbox-source' for glob 'virtualbox*'
Note, selecting 'virtualbox-guest-utils' for glob 'virtualbox*'
Note, selecting 'virtualbox-ose' for glob 'virtualbox*'
Note, selecting 'virtualbox-guest-modules' for glob 'virtualbox*'
Note, selecting 'virtualbox-guest-additions-iso' for glob 'virtualbox*'
Note, selecting 'virtualbox-guest-dkms' for glob 'virtualbox*'
Note, selecting 'virtualbox-dkms' for glob 'virtualbox*'
Note, selecting 'virtualbox-ext-pack' for glob 'virtualbox*'
Note, selecting 'virtualbox' for glob 'virtualbox*'
Note, selecting 'virtualbox-guest-source' for glob 'virtualbox*'
Note, selecting 'virtualbox-ose-fuse' for glob 'virtualbox*'
Note, selecting 'virtualbox-qt' for glob 'virtualbox*'
Note, selecting 'virtualbox-2.0' for glob 'virtualbox*'
Note, selecting 'virtualbox-2.1' for glob 'virtualbox*'
Note, selecting 'virtualbox-2.2' for glob 'virtualbox*'
Note, selecting 'virtualbox-modules' for glob 'virtualbox*'
Note, selecting 'virtualbox-3.0' for glob 'virtualbox*'
Note, selecting 'virtualbox-3.1' for glob 'virtualbox*'
Note, selecting 'virtualbox-3.2' for glob 'virtualbox*'
Note, selecting 'virtualbox-4.0' for glob 'virtualbox*'
Note, selecting 'virtualbox-4.1' for glob 'virtualbox*'
Note, selecting 'virtualbox-4.2' for glob 'virtualbox*'
Note, selecting 'virtualbox-4.3' for glob 'virtualbox*'
Note, selecting 'virtualbox-5.0' for glob 'virtualbox*'
Note, selecting 'virtualbox-5.1' for glob 'virtualbox*'
Note, selecting 'virtualbox-dbg' for glob 'virtualbox*'
Note, selecting 'virtualbox-guest-X11' for glob 'virtualbox*'
Note, selecting 'virtualbox-guest-additions' for glob 'virtualbox*'
Package 'virtualbox-ose' is not installed, so not removed
Package 'virtualbox-ose-fuse' is not installed, so not removed
Note, selecting 'virtualbox-dkms' instead of 'virtualbox-modules'
Package 'virtualbox-2.0' is not installed, so not removed
Package 'virtualbox-2.1' is not installed, so not removed
Package 'virtualbox-2.2' is not installed, so not removed
Package 'virtualbox-3.0' is not installed, so not removed
Package 'virtualbox-3.1' is not installed, so not removed
Package 'virtualbox-3.2' is not installed, so not removed
Package 'virtualbox-4.0' is not installed, so not removed
Package 'virtualbox-4.1' is not installed, so not removed
Package 'virtualbox-4.2' is not installed, so not removed
Package 'virtualbox-4.3' is not installed, so not removed
Package 'virtualbox-5.0' is not installed, so not removed
Package 'virtualbox-guest-additions' is not installed, so not removed
Package 'virtualbox-5.1' is not installed, so not removed. Did you mean 'virtualbox-5.1:i386'?
Package 'virtualbox' is not installed, so not removed
Package 'virtualbox-dbg' is not installed, so not removed
Package 'virtualbox-dkms' is not installed, so not removed
Package 'virtualbox-ext-pack' is not installed, so not removed
It is telling me that it is unable to install anything because nothing has been installed, however I am able to open VirtualBox so it must be installed. I am apprehensive about trying it out in this form.
How do I uninstall this? Or should I try to use this as it is?
karel
  • 122,292
  • 133
  • 301
  • 332
Ananda
  • 155
Maybe you are using Oracle VirtualBox instead of the VirtualBox from the official Ubuntu 16.04 repositories. When you open VirtualBox and select Help -> About VirtualBox does it say "Oracle"? If so, the terminal output in your question indicates that VirtualBox from the default Ubuntu repositories is not currently installed.
I had installed Oracle VirtualBox and that was the problem.
karel
  • 122,292
  • 133
  • 301
  • 332
