I am configuring a new web application server running Ubuntu 16.04. The only thing "unusual" I have done is install php 5.6 instead of php7. Php5.6 however does require a valid root certificate and I am getting errors in a variety of apps that care about this. Curl, cron, etc.
I have tried a variety of fixes to get this resolved with no improvement. Such as:
https://github.com/composer/composer/issues/3346#issuecomment-76593763
https://stackoverflow.com/questions/35821245/github-server-certificate-verification-failed/35824116#35824116
How do I install a root certificate?
Still no luck. The cron job I am running still generates:
curl: (60) server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle" of Certificate Authority (CA) public keys (CA certs). If the default bundle file isn't adequate, you can specify an alternate file using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in the bundle, the certificate verification probably failed due to a problem with the certificate (it might be expired, or the name might not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use the -k (or --insecure) option.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
I suggest to check the validity of the web server certificate . The steps you describe are correct, but let's get the facts about the certificate.
The steps below, I use for troubleshooting the web server certificate.
  • Check if the server name you expect is in the /CN option in subject:
(SERVER_COMMON_NAME is the webserver who you want to contact)
 echo | openssl s_client -servername ${SERVER_COMMON_NAME} \
    -connect ${SERVER_COMMON_NAME}:443 2>/dev/null | \
    openssl x509 -noout -subject
Check if the CA is the one you expect (the supplier of the cerficate):
        openssl x509 -noout -issuer
Check the /CN field in issuer line.
  • Check the dates of the certificate
        -connect ${SERVER_COMMON_NAME}:443 2> /dev/null | \
        openssl x509 -noout -dates
Check the 'notBefore' and 'notAfter' results.
  • If the above looks good, then test with curl AND specifing the CA root certificate file:
    curl --cacert certs/the_ca.cert.pem -I https://${SERVER_COMMON_NAME}:443
If --cacert option works then check if the CA-root file is system wide known.
Ommit the --cacert. If curl gives an error, then the ca-root-file is NOT installed in the system ca-certificates directory.
