I am trying to set up a USB connection to an Eaton 9130 UPS.
I have configured /etc/nut/ups.conf as such:
[Powerware9130]
driver = bcmxcp_usb
port = auto
Running /lib/nut/bcmxcp_usb -a Powerware9130 gives this:
Network UPS Tools - BCMXCP UPS driver 0.28 (2.7.2)
USB communication subdriver 0.22
Unable to find POWERWARE UPS device on USB bus (USB)
Things to try:
 - Connect UPS device to USB bus
 - Run this driver as another user (upsdrvctl -u or 'user=...' in ups.conf).
   See upsdrvctl(8) and ups.conf(5).
Fatal error: unusable configuration
lsusb -v shows this:
Bus 003 Device 004: ID 0463:ffff MGE UPS Systems UPS
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0463 MGE UPS Systems
  idProduct          0xffff UPS
  bcdDevice            0.11
  iManufacturer           1 EATON Powerware
  iProduct                2 9130
I made sure that the USB device has permissions and I even tried running bcmxcp_usb with -u root to no avail.
$ ls -l /dev/bus/usb/003/004
crw-rw-r-- 1 root nut 189, 259 May  1 22:47 /dev/bus/usb/003/004
(And in any case, the error doesn't talk about permission issues, etc...) Any idea what I might miss?
I'm running Ubuntu Server 16.04
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Might be worthwhile to try out the other driver for Eaton 9130 usbhid-ups as in
/lib/nut/usbhid-ups -a Powerware9130 -DDDDD
Also the the USB cable if it's too long can sometimes mess up the connection (I know it sounds trivial but it happened twice on my end)
Lex
  • 61
