10
The Problem
Can I make nautilus show thumbnails of book covers for files in .epub format?
It shows thumbnails for pdf files but not .epub. Is this achievable by adding a thumbnailer?
Each of these .epub files has a cover.jpeg file inside it.
Screenshot
Example Epub file (Google Drive)
No need to worry about scripts. do everything one by one
 sudo apt-get install python-pil
Now download this file from epub-thumbnailer GitHub page
now extract that file to a folder, and go into the extracted folder, Right click in empty space and select Open in Terminal and type the following command
sudo python install.py install
nautilus -q
now check your Epub files they should have thumbnails
It works like a charm in Ubuntu 22.04.01
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.1 LTS
Release:    22.04
Codename:   jammy
$ python --version Python 3.10.4
Step by step instructions
  1. Clone the epub-thumbnailer projectgit clone https://github.com/marianosimone/epub-thumbnailer.git
  2. Change directory cd epub-thumbnailer/
  3. Install Pillow pip install Pillow
  4. Install epub-thumbnailer sudo python3 install.py install
Checking dependencies ...
Required dependencies: Python Imaging Library ....... OK
Installing epub-thumbnailer to /usr/bin/ ... OK Installing thumbnailer hook in /usr/share/thumbnailers ... OK You might have to restart your file manager for the thumbnailer to be activated.
  1. Clear the cache rm -rf ~/.cache/thumbnails
  2. Restart your file manager
  3. Done!
Using gnome-epub-thumbnailer
GNOME has a thumbnailer for EPUB files that is not installed by default. It's called gnome-epub-thumbnailer. Install it from the Ubuntu repositories like this:
sudo apt install gnome-epub-thumbnailer
Then restart the Files application (also known as Nautilus) by running nautilus --quit. Now it should work beautifully:
Screenshot
Flimm
  • 44,031
