I was installing cuda-8.0 for my project and followed this link, which asked me to download Nvidia Driver using .run file:
http://queirozf.com/entries/installing-cuda-tk-and-tensorflow-on-a-clean-ubuntu-16-04-install
along with which I blacklisted Nouveau Driver.
The installation was done by executing sudo service lightdm stop and then running the .run file.
Initially I faced some difficulties like login loop and black screen, but later solved them.
Now, when i try to execute commands like:
command: lspci -vnn | grep -i VGA -A 12 , gives output:
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:5916] (rev 02) (prog-if 00 [VGA controller])
    DeviceName:  Onboard IGD
    Subsystem: Dell Device [1028:0782]
    Flags: bus master, fast devsel, latency 0, IRQ 280
    Memory at d4000000 (64-bit, non-prefetchable) [size=16M]
    Memory at b0000000 (64-bit, prefetchable) [size=256M]
    I/O ports at f000 [size=64]
    [virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
    Capabilities: <access denied>
    Kernel driver in use: i915
    Kernel modules: i915
command: glxinfo | grep OpenGL | grep renderer, gives the output:
OpenGL renderer string: Mesa DRI Intel(R) Kabylake GT2
command: sudo lshw -c video, gives the output:
  *-display
       description: VGA compatible controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 02
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:280 memory:d4000000-d4ffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
  *-display
       description: 3D controller
       product: GM108M [GeForce 940MX]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a2
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list rom
       configuration: driver=nvidia latency=0
       resources: irq:16 memory:d2000000-d2ffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:d3000000-d307ffff
command: lsmod | grep nv, gives the output:
nvidia_uvm            647168  0
nvidia_drm             49152  0
nvidia_modeset        790528  1 nvidia_drm
nvidia              12144640  2 nvidia_modeset,nvidia_uvm
drm_kms_helper        167936  2 i915,nvidia_drm
drm                   368640  6 i915,nvidia_drm,drm_kms_helper
I think, the Nvidia driver is installed, but still not activated as the kernel driver.
Can someone help me figuring out the problem and how to solve it?
Please ask if any other info is needed.
BTW, driver version is NVIDIA-Linux-x86_64-375.39 on Ubuntu 16.04
Update 1:
screenshot of distorted window
