I have a /boot overload.
Tried to follow /dev/sda1 /boot is full, but got stuck.
History:
df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 485360 0 485360 0% /dev
tmpfs 100744 10824 89920 11% /run
/dev/mapper/vg00-lv01 49011528 7513836 39300100 17% /
tmpfs 503716 0 503716 0% /dev/shm
tmpfs 5120 0 5120 0% /run/lock
tmpfs 503716 0 503716 0% /sys/fs/cgroup
/dev/sda1 474730 466955 0 100% /boot
dpkg --list | grep linux-image
ii linux-image-4.4.0-21-generic 4.4.0-21.37 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-59-generic 4.4.0-59.80 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-62-generic 4.4.0-62.83 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-63-generic 4.4.0-63.84 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-64-generic 4.4.0-64.85 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-66-generic 4.4.0-66.87 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-67-generic 4.4.0-67.88 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-70-generic 4.4.0-70.91 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-71-generic 4.4.0-71.92 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-4.4.0-72-generic 4.4.0-72.93 amd64 Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-21-generic 4.4.0-21.37 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-59-generic 4.4.0-59.80 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-62-generic 4.4.0-62.83 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-63-generic 4.4.0-63.84 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-64-generic 4.4.0-64.85 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-66-generic 4.4.0-66.87 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-67-generic 4.4.0-67.88 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-70-generic 4.4.0-70.91 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
ii linux-image-extra-4.4.0-71-generic 4.4.0-71.92 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
iF linux-image-extra-4.4.0-72-generic 4.4.0-72.93 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
iU linux-image-extra-4.4.0-75-generic 4.4.0-75.96 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
iU linux-image-generic 4.4.0.75.81 amd64 Generic Linux kernel image
!!! wow, so much, how could this happen ?
And then:
uname -r
4.4.0-21-generic
Trials to purge unused images:
apt-get purge linux-image-4.4.0-59-generic
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
linux-image-extra-4.4.0-59-generic : Depends: linux-image-4.4.0-59-generic but it is not going to be installed
linux-image-extra-4.4.0-75-generic : Depends: linux-image-4.4.0-75-generic but it is not going to be installed
linux-image-generic : Depends: linux-image-4.4.0-75-generic but it is not going to be installed
Recommends: thermald but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Anyone got an idea?
