I'm about to buy a Laserjet multifunction wireless printer, and I was thinking about the HP LaserJet Pro M130fw
I searched online for a while and all I could find is this thread on the Linux Mint forums
And this on hp forums.
Anybody had luck using this printer on Linux? Or should I go for a similar model with better Linux support?
Zanna
  • 72,312
opensas
  • 3,257
YES. It's working with the new LTS version of Ubuntu, 18.04, and out of the box! It appears that it gives you the option to use different printers (in reference to the drives and such), so select the appropriate one, in this case being the hp laserjet pro m130fw. Although it is using the hp laserjet m129 as its driver, you still have to point to the printer, being the m130. It'll work. Does that make sense?
I am professional at installing printers on Ubuntu, but I tried my best and I could not install it on my laptop.
  • Printer : HP LaserJet Pro MFP M130fw
  • Ubuntu : Ubuntu 16.04.4 LTS
I tried, USB / wireless, with and without hplip.
So, maybe it is late but for the future users, I am not suggesting it for Ubuntu so far.
I got it working on ubuntu 14.04 LTS: Visited https://developers.hp.com/hp-linux-imaging-and-printing and downloaded the latest hplip program from their site. After you do the same, open terminal (ctrl+alt+t), change to the directory where it was downloaded (cd directory_name) and run the program with commands:
sudo chmod +x hplip-[DOWNLOADED_VERSION].run
./hplip-[DOWNLOADED_VERSION].run
(obviously change the [DOWNLOADED_VERSION] to the one you've downloaded). The setup takes some time but is pretty straight forward, just remember to overwrite the existing version of the program as ubuntu 14 already has it (but not in the latest version it seems).
After that I could easily add the printer via the installed HP Device Manager. It prints fine. Didn't test the scanning option yet but I got it working on another machine (with ubuntu 18.04 however) and I suppose it can be done as well.
