I used kubuntu ppa to install kubuntu-desktop on Ubuntu unity 16.04, the canonical one. It led to broken packages. As others have pointed out here and here, they figured out how to install kubuntu-deskop anyway however, I am not inclined to use plasma anymore. So I am uninstalling it. I just unchecked the kubuntu ppa/backports/Ubuntu Xenial in Softwares & Updates > Other Software. And then sudo apt-get remove kubuntu-desktop. I later realized that this was not the best way to rid my system of the kubuntu system conflicting with my unity DE. Anyway I learnt this the hard way when I was trying to install unity tweak tools.
So basically I realized that I had not gotten rid of softwares installed by the ppa in a good way leading to broken packages. Now I do not notice this when installing other packages. Only when dealing with qt, unity etc. I face this issue. I tried installing all unity stuff hoping this will remove all the kubuntu related packages.
sudo apt-get install unity-*
I got this error:-
unity-chromium-extension : Depends: webbrowser-app
unity-scope-click : Depends: account-plugin-ubuntuone
Depends: pay-service but it is not going to be installed
Depends: ubuntu-sdk-libs but it is not going to be installed
unity-scope-click-autopilot : Depends: ubuntu-ui-toolkit-autopilot but it is not going to be installed
Depends: unity8-autopilot but it is not going to be installed
unity-scope-home : Conflicts: unity-scope-deviantart
Conflicts: unity-scope-gallica
Conflicts: unity-scope-github
Conflicts: unity-scope-googlenews
Conflicts: unity-scope-openweathermap
Conflicts: unity-scope-soundcloud
Conflicts: unity-scope-yahoostock
unity-scope-tool : Depends: unity8-common (= 8.12+16.04.20160401-0ubuntu1) but it is not going to be installed
unity-webapps-qml : Depends: qtdeclarative5-ubuntu-ui-toolkit-plugin or
qtdeclarative5-ubuntu-ui-toolkit-plugin-gles but it is not going to be installed
unity-webapps-service : Depends: webapp-container
unity8-private : Depends: pay-service but it is not going to be installed
Depends: qtdeclarative5-gsettings1.0 but it is not going to be installed
Depends: qtbase-abi-5-5-1
Depends: qtdeclarative-abi-5-5-0
Elsewhere they advise to clean, auto-clean, upgrade,dist-upgrade,auto-remove etc. Tried all, but no result. Unity seems to be in conflict. interestingly when I try :-
sudo apt-get install python3-pyqt5
It runs into error:-
python3-pyqt5 : Depends: qtbase-abi-5-5-1
Using aptitude also is futile. It just says i cannot resolve your problem and does nothing. Can someone help me figure out how to remove kubuntu and the other softwares properly and reinstall unity properly.
