So I am currently installing Caffe and I'm already in this part:
No, this does not help the Ubuntu 16.04 for now. You could try to pass an argument (CXX_FLAGS) to the compiler -D_FORCE_INLINES by editing the CMAKE files (for example: set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -D_FORCE_INLINES")) or makefiles. The procedure is not specified. This should work, or you must wait for an updated Cuda Toolkit sources to compile with the associated software in Ubuntu 16.04 such as Caffe, Torch and Theano.
I'm following this guide: https://github.com/intel/caffe/wiki/Ubuntu-16.04-or-15.10-Installation-Guide
I don't exactly know what this means. Can someone please explain this to me in detailed steps? Thank you!
karel
  • 122,292
  • 133
  • 301
  • 332
Although not a direct answer to your question about BUILDING caffe, i found the best way to get up and running is to use conda. First start by making an environment
conda create -n caffe
then
conda install caffe
OR
conda install caffe-gpu
Not only does conda solve all the dependencies but it also installs the correct version of cudatoolkit and cudnn. And if you want python 2 you can
conda create -n python2Caffe-GPU python=2.7
conda install caffe-gpu=1.0=py27heda4471_3
The variable, py27heda4471_3, is the build version and you have many to choose from
conda search caffe-gpu
gives a list
