I was runing ntfsfix on ubuntu for my "exFat" Data. Is there any method to repair my data back to correct format?
Thanks so Much!
Tony
Why would you even attempt to use a tool for NTFS on a filesystem that is not NTFS?
Exfatfsck should be used to check exFat. Mind though that this tool can only be used to perform a check. Testdisk can retrieve data from exFat but that also does not fix your filesystem.
But there is no native Linux tool to repair exFat. Use Windows to fix the problem.
Pang
  • 373
Rinzwind
  • 309,379
-1
use testdisk. create --> your disk --> choose table type --> Advanced --> choose your disk partition --> use arrow left and right to choose "Type" --> MSData --> exfat.
use arrow left and right to choose "Boot" --> use arrow left and right to choose BACKUP BS.
