I recently switched to Kubuntu 17.04 it's amazing but I didn't like dolphin (file manager that comes with KDE suite), so I tried to install Nautilus by doing This
sudo add-apt-repository ppa:gnome3-team/gnome3
sudo apt-get update && sudo apt-get install nautilus
This should have installed Nautilus but it gave me an error
W: The repository 'http://ppa.launchpad.net/docky-core/stable/ubuntu zesty Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://ppa.launchpad.net/docky-core/stable/ubuntu/dists/zesty/main/binary-amd64/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
What does this actually mean? Will I not be able to install Nautilus in Kubuntu 17.04?
Zanna
  • 72,312
Well it's available in default repositories, so no need to add any PPA.
First of all delete the added PPA by running the following command:
sudo add-apt-repository --remove ppa:gnome3-team/gnome3
then install Nautilus from normal repository with the following command:
sudo apt install nautilus
Zanna
  • 72,312
