l have trouble with my PATH variable:
each time l run command like pip, bash, mkdir ..
for instance
The command could not be located because '/bin' is not included in the PATH environment variable.
bash: command not found
other example :
dpkg: warning: 'sh' not found in PATH or not executable
dpkg: warning: 'rm' not found in PATH or not executable
dpkg: warning: 'tar' not found in PATH or not executable
dpkg: warning: 'ldconfig' not found in PATH or not executable
dpkg: warning: 'start-stop-daemon' not found in PATH or not executable
dpkg: error: 5 expected programs not found in PATH or not executable
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
E: Sub-process /usr/bin/dpkg returned an error code (2)
does this command solves the problem ?
export PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
each time l need to run this command , how to solve that ?
This command:
/bin/grep PATH ~/.bashrc ~/.profile ~/.bash_profile ~/.bash_login /etc/profile /etc/bash.bashrc /etc/environment
returns:
/root/.bashrc:export PATH="/root/anaconda3/bin"
/bin/grep: /root/.bash_profile: No such file or directory
/bin/grep: /root/.bash_login: No such file or directory
/etc/environment:PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
terdon
  • 104,119
vincent
  • 571
  • 14
The problem is in /root/.bashrc, specifically this line:
First of all, what in the world are you doing adding anaconda to root's PATH? You really don't want to be using root as your main user! Anyway, that line doesn't add /root/anaconda3/bin to root's PATH, it replaces the PATH with /root/anaconda3/bin and nothing else. So the only command that root can run are the ones in /root/anaconda/bin. What you wanted to do, presumably, was add it. So, change the line above to:
export PATH="$PATH:/root/anaconda3/bin"
Since your PATH is currently messed up, you will need to use the full paths to the relevant commands. For example, to open the file using nano:
/bin/nano /root/.bashrc
Or, if you are not actually logged in as root (as you shouldn't be):
/usr/bin/sudo /bin/nano /root/.bashrc
Then correct the line, open a new terminal (or log out and log back in) and everything should work again.
terdon
  • 104,119
