The default resolution doesn't fit my screen. It works perfectly in the recovery mode but in the normal boot I can only get a big resolution. It sais The CRTC 381 is not to be found.
I would like to have a resolution of 1024x768 61Hz.
$ sudo lshw -c video
*-display UNCLAIMED
       product: 4 Series Chipset Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 03
       width: 64 bits
       clock: 33MHz
       capabilities: msi pm vga_controller bus_master cap_list
       configuration: latency=0
       resources: memory:fe400000-fe7fffff memory:e0000000-efffffff ioport:dc00(size=8)
Ubuntu 14.04 LTS
What I tried
  • I had this problem also with Ubuntu 12.04. There the solution was to change the Xorg.conf file, but such file is missing.
  • Tried using xrandr but doesn't seem to work.
I hope sombody can help so I don't have to start in the recovery mode each time.
Greetings
M. Becerra
  • 3,538
  • 24
  • 40
Smitje
To give appropriate advice facts are neccessary, results of commands are needed.
Saying "it doesn't work" makes sense to you but we can't see what you are seeing.
I'm sure you understand what I mean.
The output of xrandr is the usual starting point for us to get an understanding of your configuration. If the command gives an error, that too maybe vital information.
I found it on this forum...
markward@markward-desktop:~$ cvt 640 480 60
    # 640x480 59.38 Hz (CVT 0.31M3) hsync: 29.69 kHz; pclk: 23.75 MHz
    Modeline "640x480_60.00"   23.75  640 664 720 800  480 483 487 500 hsync +vsync
markward@markward-desktop:~$  xrandr --output LVDS --mode 1024x768
    xrandr: Failed to get size of gamma for output default
    warning: output LVDS not found; ignoring
markward@markward-desktop:~$  xrandr --output VGA1 --mode 1024x768
warning: output VGA1 not found; ignoring
markward@markward-desktop:~$  xrandr --addmode S-video 1024x768
    xrandr: cannot find output "S-video"
  • and also this is the error mesage i get starting up... it means non of the selected modi are compatible with the possible modi
  • I don't get this message if I start up in the recovery mode
    geen van de geselecteerde modi waren compatibel met de mogelijke modi: Proberen modi voor CRTC 379
    CRTC 379: uitproberen modus 640x480@73Hz met uitvoer op 1024x768@61Hz (ronde 0)
    CRTC 379: uitproberen modus 640x480@73Hz met uitvoer op 1024x768@61Hz (ronde 1)
This is the only resolution option available
Screen 0: minimum 640 x 480, current 640 x 480, maximum 640 x 480
    default connected primary 640x480+0+0 0mm x 0mm
   640x480        73.0*
  • I also found this
     lspci|grep -i vga
     00:02.0 VGA compatible controller: Intel Corporation 4 Series Chipset Integrated Graphics Controller (rev 03)
  • and this
      cvt -v 1024 678 60
      Warning: Aspect Ratio is not CVT standard.
      # 1024x678 59.81 Hz (CVT) hsync: 42.17 kHz; pclk: 56.00 MHz
      Modeline "1024x678_60.00"   56.00  1024 1072 1176 1328  678 681 691 705 -hsync +vsync
Smitje
  • Ican't find the mentioned file fglrx-core.conf
  • What I do find in /etc/modprobe.d is:
     markward@markward-desktop:/etc/modprobe.d$ dir
     alsa-base.conf             blacklist-modem.conf         iwlwifi.conf
     blacklist-ath_pci.conf     blacklist-oss.conf           libpisock9.conf
     blacklist.conf             blacklist-rare-network.conf  mlx4.conf
     blacklist-firewire.conf    blacklist-watchdog.conf      vmwgfx-fbdev.conf
     blacklist-framebuffer.conf fbdev-blacklist.conf
Smitje
