I would like to install dconf-editor on Ubuntu 17.04 64-bit. This tutorial suggests it should be pretty easy - running apt install dconf-editor should be sufficient. It does not work however and prints this message instead:
Reading package lists... Done
Building dependency tree
E: Unable to locate package dconf-editor
What happened to the dconf-editor package?
Additional details
  • apt-cache policy dconf-editor returns:
    N: Unable to locate package dconf-editor
  • apt update does not help.
If you have rmadison installed you can simply run:
rmadison dconf-editor | grep zesty
to find out if this package is available for zesty. here is my output:
 dconf-editor | 3.23.4-0ubuntu1 | zesty/universe   | source, amd64, arm64, ...
So it's there and it's in universe component; to find out if you have access to install it run:
If you get nothing, I guess something is wrong with your sources.list, run:
grep "^deb " /etc/apt/sources.list
to check your sources.list file; you should have some lines look like this:
deb http://archive.ubuntu.com/ubuntu/ zesty universe
deb http://archive.ubuntu.com/ubuntu/ zesty-updates universe
If you dont, add them, update your sources; then install the program.
Ravexina
  • 57,256
It turns out that my /etc/apt/sources.list didn't have the default repositories - they must have been overwritten - and this is why I couldn't install anything with apt.
The solution is to restore the contents of /etc/apt/sources.list:
  1. If you're lucky then you've got a backup file /etc/apt/sources.list.save from which you can restore the list of repositories.
  2. Otherwise, I've found this website which is able to generate a list of repositories from scratch: https://repogen.simplylinux.ch/.
  3. Also as Ravexina added in the comments:
    You can also use this file to restore your sources: /usr/share/doc/apt/examples/sources.list, just change the codename and add your desired components.
