I normally start Skype and it appears in the upper panel and works. But now when I start it, it doesn't appear! But it works like normal. Stackapplet is appearing in the panel.
My whitelist: ['JavaEmbeddedFrame', 'Mumble', 'Wine', 'Skype', 'hp-systray', 'scp-dbus-service', 'jupiter']
I've tried
  • to remove jupiter
  • to purge skype
  • to delete the panel and create a new one
This is how it looks right now. all my other applications work except Skype. enter image description here
I guess this is not a normal message to get when I type: skype -version ?!
Skype version: 2.2.0.35
Alvar
  • 17,038
Skype does not use the standard indicator-applet functionality in Natty to show its Icon.
Instead it requires the old Notification-Area-Applet (right click the Panel and "Add To Panel") for it to work correctly.
You can double check that this applet is running by running the following command in a terminal window:
killall -9 "notification-area-applet"
If it responds with a "notification-area-applet: no process found" error message then the applet is not running (i.e. has not been added to the gnome-panel)
fossfreedom
  • 174,526
