I wanted to try an application (Kamoso) but its installation failed, and now a system tray icon tells me:
An error occurred ... run Package Manager or apt-get to see what is wrong. Error: BrokenCount>0
$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
  kde-config-telepathy-accounts
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 10 not upgraded.
2 not fully installed or removed.
Need to get 0 B/148 kB of archives.
After this operation, 808 kB of additional disk space will be used.
  Do you want to continue? [Y/n] y
    (Reading database ... 1330003 files and directories currently installed.)
    Preparing to unpack .../kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_i386.deb ...
    Unpacking kde-config-telepathy-accounts (4:15.12.3-0ubuntu1) ...
    dpkg: error processing archive /var/cache/apt/archives/kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_i386.deb (--unpack):
     trying to overwrite '/usr/share/accounts/services/google-im.service', which is also in package account-plugin-google 0.12+16.04.20160126-0ubuntu1
    Processing triggers for libc-bin (2.23-0ubuntu7) ...
Ubuntu software centre fails repairing:
    installArchives() failed: (Reading database ...
(Reading database ... 100%
dpkg: dependency problems prevent configuration of kde-telepathy-minimal:
 kde-telepathy-minimal depends on kde-config-telepathy-accounts (>= 15.04.0); however:
  Package kde-config-telepathy-accounts is not installed.
dpkg: error processing package kde-telepathy-minimal (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of kde-telepathy:
 kde-telepathy depends on kde-telepathy-minimal (= 15.04.20ubuntu1); however:
  Package kde-telepathy-minimal is not configured yet.
dpkg: error processing package kde-telepathy (--configure):
I tried to remove or purge kde-telepathy-minimal or kde-telepathy:
$ sudo apt-get purge kde-telepathy
You might want to run 'apt-get -f install' to correct these:
 kde-telepathy-minimal : Depends: kde-config-telepathy-accounts (>= 15.04.0) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Could you please help me remove either of the packages, as a solution to clean up this broken installation and get the package manager back to work?
Zanna
  • 72,312
ubuntubu
  • 453
Thanks to @user535733 for the useful comment: "Use dpkg to uninstall the offending (conflicting) package, then use apt to clean up the dependencies"
Here's how I removed the conflicting packages:
$ sudo dpkg --remove kde-telepathy
(Reading database ... 1330002 files and directories currently installed.)
Removing kde-telepathy (15.04.20ubuntu1) ...
$ sudo dpkg --remove kde-telepathy-minimal
(Reading database ... 1329999 files and directories currently installed.)
Removing kde-telepathy-minimal (15.04.20ubuntu1) ...
Afterwards I cleaned up with
sudo apt autoremove
Zanna
  • 72,312
ubuntubu
  • 453
