I'm trying to follow the solution in this thread to disable extra touchpad device so that syndaemon will work to disable the touchpad while typing so I won't keep having a jumping cursor (very hard to type right now)!
Having trouble following the instructions, not familiar with Ubuntu that much. I enter the following:
sudo gedit /usr/share/X11/xorg.conf.d/51-synaptics-quirks.conf
That opens the text file. I then paste the following:
# Disable generic Synaptics device, as we're using
# "DLL0704:01 06CB:76AE Touchpad"
# Having multiple touchpad devices running confuses syndaemon
Section "InputClass"
    Identifier "SynPS/2 Synaptics TouchPad"
    MatchProduct "SynPS/2 Synaptics TouchPad"
    MatchIsTouchpad "on"
    MatchOS "Linux"
    MatchDevicePath "/dev/input/event*"
    Option "Ignore" "on"
EndSection
Then click save and get the following errors:
** (gedit:6473): WARNING **: Set document metadata failed: Setting attribute metadata::gedit-spell-language not supported
** (gedit:6473): WARNING **: Set document metadata failed: Setting attribute metadata::gedit-encoding not supported
** (gedit:6473): WARNING **: Set document metadata failed: Setting attribute metadata::gedit-position not supported
So not able to fully complete this solution. Let me know if you can help so I can perhaps make this new Dell Inspiron 15 7579 usable (trying both 17.04 on thumb drive and 16.04 LTS on external hard drive).
Nick C
  • 65
I've been having the exact same problem. The protocol seems specific to Dell and provides a means to disable the Synaptics driver. So far it is working for me.
Dell Support: Erratic cursor movement on the XPS 13/15 series laptops and Precision Mobile Workstations with Ubuntu 16.04 installed
  1. Open a terminal and run in this command:
     sudo nano /etc/modprobe.d/xps13-9360.conf
    (replace "xps13-9360" with the particulars of your own Dell laptop, i.e. "Inspiron15-7579")
  2. Type blacklist psmouse and press Enter
  3. Press Ctrl+X to save.
  4. Press Enter to verify the changes made to the file name.
  5. You should now be back to the terminal. Type the command sudo update-initramfs –u && sudo reboot and press Enter
