I recently installed a video converter software and later I removed it.
After removing it, I can't seem to install any other software. It seems when I removed the video converter software, it also removed some library that is necessary for other software to be installed, too.
Now, I want to install monodevelop, but it again notifies so much dependencies!
Here is what my terminal says:
$ sudo apt-get install monodevelop
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
mobilemediaconverter:i386 : Depends: libglib2.0-0:i386 (>= 2.2.0)
Depends: libgtk2.0-0:i386 (>= 2.2.0)
Depends: mencoder:amd64
monodevelop : Depends: gnome-icon-theme (>= 1.1.3) but it is not going to be installed
Depends: monodoc-manual (>= 1.1.9) but it is not going to be installed
Depends: mono-runtime-sgen but it is not going to be installed
Depends: mono-xbuild but it is not going to be installed
Depends: mono-runtime (>= 3.0~) but it is not going to be installed
Depends: libgconf2.0-cil (>= 2.24.0) but it is not going to be installed
Depends: libglade2.0-cil (>= 2.12.10-1ubuntu1) but it is not going to be installed
Depends: libglib2.0-cil (>= 2.12.10-1ubuntu1) but it is not going to be installed
Depends: libgnome-vfs2.0-cil (>= 2.24.0) but it is not going to be installed
Depends: libgnome2.24-cil (>= 2.24.0) but it is not going to be installed
Depends: libgtk2.0-cil (>= 2.12.10-1ubuntu1) but it is not going to be installed
Depends: libmono-cairo4.0-cil (>= 4.0.4.1) but it is not going to be installed
Depends: libmono-corlib4.5-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-microsoft-build-engine4.0-cil (>= 3.2.1) but it is not going to be installed
Depends: libmono-microsoft-build-framework4.0-cil (>= 3.6.0) but it is not going to be installed
Depends: libmono-microsoft-build-utilities-v4.0-4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-posix4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed
Depends: libmono-sharpzip4.84-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-componentmodel-dataannotations4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed
Depends: libmono-system-configuration4.0-cil (>= 4.0.0~alpha1) but it is not going to be installed
Depends: libmono-system-core4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-system-data-services-client4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-data4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-system-design4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed
Depends: libmono-system-numerics4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-runtime-serialization4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-system-runtime4.0-cil (>= 2.10.1) but it is not going to be installed
Depends: libmono-system-security4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed
Depends: libmono-system-web-mvc3.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-web-razor2.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-web-services4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-system-web-webpages-razor2.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed
Depends: libmono-system-windows-forms4.0-cil (>= 1.0) but it is not going to be installed
Depends: libmono-system-xaml4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-system-xml-linq4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-system-xml4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-system4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libmono-windowsbase4.0-cil (>= 4.2.0) but it is not going to be installed
Depends: libwebkitgtk-1.0-0 (>= 1.3.9) but it is not going to be installed
Depends: monodoc-base (>= 3.2.1) but it is not going to be installed
Recommends: libglade2.0-cil-dev but it is not going to be installed
Recommends: libgtk2.0-cil-dev but it is not going to be installed
Recommends: mono-devel but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Please, can you give me any solution to the problem.
