I bought a Windows 10 notebook and need Linux on it (my first linux experience).
The notebook only have a 32gb ssd, I use a linux live with Ubuntu 16.04 and did not boot after successfull installation (I choose to format everything). I use boot-repair and still not booting (http://paste2.org/hJ9XGkJy), already put the ssd on priority of booting. I tried to install grub with mount but show errors like failed to get canonical path of 'aufs'. Please some help, I already read a ton of other pages and lost a day with this (trying the same method over and over).
- 9,296
- 11
- 3
Your computer uses an NVMe disk, which appears in Ubuntu via the /dev/mmcblk0 device. Most disks in Ubuntu appear via devices called /dev/sda, /dev/sdb, and so on. It looks like Boot Repair might not be quite handling that correctly. At the very least, it's not showing the partition table on your /dev/mmcblk0 device. Although the repair looks like it probably did what it should have done, there are also some errors reported (like on line 676 and 679), so I'm not 100% sure that it's completed correctly. I recommend you contact the Boot Repair developers about this; NVMe disks with filenames of the form /dev/mmcblk* are becoming more common, and Boot Repair should be able to handle them correctly.
That said, if these issues aren't critical (and they may not be), it's possible that your firmware is one of the still-too-common broken EFIs that forget or ignore their built-in boot managers' NVRAM-based boot entries. I say this because the first efibootmgr output, on lines 254-264, shows a BootOrder variable that does not include the ubuntu entry. The same is true of the second efibootmgr output, on lines 624-634. The third instance, on lines 656-666, shows the result of the repair and shows the ubuntu entry as being active and the default option in the BootOrder. The thing is that the BootOrder variable should have been correct from the start; the fact that it wasn't correct, but that an ubuntu entry was present, implies that the BootOrder variable was altered after the OS was installed. The usual cause of this problem is a defective firmware.
If I'm right, you may need to either return the computer for a refund (if it's new enough for this) or use an ugly, hackish workaround, as described in my answer to this question. The Boot Repair utility can also do this semi-automatically; you need to set the option to back up and rename boot loaders on the "advanced" menu, then re-repair the installation.
- 45,120
- 7
- 66
- 108
