I have a Lenovo ThinkPad T60P with 4GB of memory (BIOS sees all 4GB RAM). I have installed Ubuntu 11.04 and 11.10 and both are only recognizing 3GB RAM. Please advise.
Thanks.
Updates
Used 32bit ver for both 11.04 and 11.10. Just installed 11.10 64 bit and machine now only sees 2.9 gb.
Intel Core 2 Duo Processor T7600
ThinkPad-T60p:~$ uname -a Linux ThinkPad-T60p 3.0.0-14-generic
 #23-Ubuntu SMP Mon Nov 21 20:28:43 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
flags: fpu vme de pse tsc msr PAE mce cx8 apic  etc, etc...
4GB of Crucial RAM, memory test Passed. Current BIOS is 2.27 dated 3/21/11
Sending memory back to vendor for replacement. Hope that takes care of it.
Tom Brossman
  • 13,297
user39440
  • 363
32 bit Ubuntu should detect > 4GB RAM at install and 'automagically' enable Physical Address Extensions, which lets you use up to 64GB RAM. Not in exactly the same way as 64 bit installs, but you can see it and use it. Check that your processor supports this first:
grep --color=always -i PAE /proc/cpuinfo
I had this same laptop (excellent machine, btw) with 4GB RAM and this all worked just fine.
Failing that, you can test your memory to make sure it is not the culprit here. You need to choose memtest86 at the GRUB menu. You can do this from the Live CD or USB if you have just one OS installed and don't usually see GRUB at boot.
If none of this helps, post an update to your question with more info and we can help you some more.
Tom Brossman
  • 13,297
Not sure why Rogelio is being down voted. He is correct. There is a PHYSICAL hardware limitation where the last GB of the 4GB is unable to be allocated. No matter what you do, a T60P with this chipset regardless of operating system is going to only report a maximum of 3GB of RAM. Even in the link Rogelio provided, it says regardless of OS it will not report more than 3GB of RAM to the OS. Why Tom Brossman thinks that link is for Windows only makes me think he needs to learn how to read and stop telling people they are wrong.
I verified this all myself. Ubuntu 15.04 32-bit which has PAE enabled in the generic kernel by default (and has been since 12.10) only sees 3GB of RAM. Ubuntu 64-bit also only sees 3GB of RAM.
Why is more than 3GB of RAM not recognised when using amd64?
-1
Refer to http://support.lenovo.com/en_US/product-and-parts/detail.page?DocID=PD008795
The note on MEMORY paragraph explains what chipsets only recognize 3GB even if the laptop has 4GB installed.
Then the OS needs to be 64bit in order to have the full 4GB available on the laptop whose chipset will support that memory size.
