I just finished upgrading from 16.04 to 16.10 and am planning to upgrade to 17.04 later.
During the upgrade there were a couple of errors but the installation managed to finish and the computer is running fine.
Except that when I write sudo apt-get upgrade I get the following output:
$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
iptables : Depends: libxtables11 (= 1.6.0-2ubuntu3) but 1.6.0-3ubuntu2 is installed
systemd-sysv : Conflicts: systemd-shim but 9-1bzr4ubuntu1 is installed
N: Ignoring file '50unattended-upgrades.ucf-dist' in directory '/etc/apt/apt.conf.d/' as it has an invalid filename extension
E: Unmet dependencies. Try using -f'
And it doesn't allow me to continue upgrading.
EDIT: I've run apt-get -f install and got this output:
Correcting dependencies... Done
The following additional packages will be installed:
iptables
The following packages will be REMOVED:
systemd-shim
The following packages will be upgraded:
iptables
1 upgraded, 0 newly installed, 1 to remove and 4 not upgraded.
1 no t fully installed or removed.
Need to get 0 B/252 kB of archives.
After this operation, 143 kB disk space will be freed.
Do you want to continue? [Y/n] y
N: Ignoring file '50unattended-upgrades.ucf-dist' in directory '/etc/ap/apt.conf.d/' as it has an invalid filename extension
(Reading database ... 946072 files and directories currently installed.)
Removing systemd-shim (9-1bzr4ubuntu1) ...
Removing 'diversion of /usr/share/dbus-1/system-services/org.freedesktop.systemd1.service to /usr/share/dbus-1/system-services/org.freedesktop.systemd1.service.systemd by systemd-shim'
dpkg-divert: error: rename involves overwriting '/usr/share/dbus-1/system-services/org.freedesktop.systemd1.service' with
different file '/usr/share/dbus-1/system-services/org.freedesktop.systemd1.service.systemd', not allowed
dpkg: error processing package systemd-shim (--remove):
subprocess installed post-removal script returned error exit status 2
systemd-shim
EDIT: output for apt-cache policy iptables libxtables11 systemd-sysv systemd-shim:
iptables:
Installed: 1.6.0-3ubuntu2
Candidate: 1.6.0-3ubuntu2
Version table:
*** 1.6.0-3ubuntu2 500
    500 http://archive.ubuntu.com/ubuntu zesty/main amd64 Packages
    500 http://ftp-stud.hs-esslingen.de/ubuntu zesty/main amd64 Packages
    100 /var/lib/dpkg/status
libxtables11:
Version table:
systemd-sysv:
Installed: 232-21ubuntu3
Candidate: 232-21ubuntu3
Version table:
*** 232-21ubuntu3 500
    500 http://ftp-stud.hs-esslingen.de/ubuntu zesty-updates/main amd64 Packages
 232-21ubuntu2 500
systemd-shim:
Installed: 9-1bzr4ubuntu1
Candidate: 9-1bzr4ubuntu1
Version table:
*** 9-1bzr4ubuntu1 100
