I want to make a zenity question that goes further depending on the answer you choose.
The question in my script is:
zenity --question --text="Would you like to participate in a little form?"
_
Full script
#!/bin/bash
if [ "$(whoami)" != "root" ]; then
  echo "Put this is /sbin/ and chmod 755 it."
else
    zenity --info --text="Hi! Welcome to !!Name yet to be found!!"
    sleep 0.5
    sleep 1
    zenity --info --text="Getting important run files"
    wget
    sleep 1
    zenity --info --text="Done!"
    sleep 1
    zenity --info --text="I will this program will move to /sbin/ and chmod
775 it for you!
No need to thank me.
My program creator made me this way :("
    sudo chmod 755 ~/!!!
    mv ~/!!! /sbin/
    sleep 1
    sleep 2
    sudo xdg-open /sbin
    zenity --info --text="Well look for yourself!"
    sleep 10
    zenity --info --text="Dont rerun this file!"
    echo
    zenity --info --text="This is just the install part."
fi
How can I achieve this?
derHugo
  • 3,376
  • 34
  • 52
EraySP909
  • 93
zenity --question will return the user's answer in its exit code. You can collect it from the $? special variable, like so
zenity --question --text="Are you there?"
THERE=$?
or use it directly in a conditional like this
if zenity --question --text="Do you want to answer stupid questions?"
then
    zenity --entry --text="Why?"
fi
derHugo
  • 3,376
  • 34
  • 52
Tilman
  • 3,769
