I did try to upgrade the ubuntu 16.04 LTS to 17.04 using information from this link :
After switching you’ll need to run a quick update (it’ll prompt you to do this anyway) and then you’ll need to upgrade to Ubuntu 16.10 (yes, 16.10).
sudo do-release-upgrade -d
Once that upgrade has completed reboot, login and run the command again, this time to upgrade to Ubuntu 17.04.
When I tried to upgrade 16.04 to 16.10 with sudo do-release-upgrade -d , the pc was turned off ( Mr X took off the battery ) so the upgrade was interrupted , but still everything working right and I continued upgrading to 17.04.
now I have a problem :
  • when I run sudo apt-get update it doesn't show all the dependencies
  • when I run sudo apt-get upgrade it return this: enter image description here
is there any way to fix these issues ?
I'm able to upgrade from 16.04 to 17.04 by following command sequence.
sudo apt update && sudo apt dist-upgrade
Then tried the following command as suggested in internet
result : System is up-to date, actually newer version available
Then tried to find which version available by issuing this command
thiru@ubuntu:~/work$ sudo do-release-upgrade -c
Checking for a new Ubuntu release
New release '17.04' available.
Run 'do-release-upgrade' to upgrade to it.
So, run this command to upgrade successfully as suggested by command output.
After this my Ubuntu updated to 17.04 successfully.
ntshetty
  • 161
I don't now if it doomed something else on the system but it works out for my problem:
sudo -i                       # to be the superuser
dpkg --purge unity-plugin-scopes:amd64 url-dispatcher:amd64 url-dispatcher-tools unity8-common unity8 unity-greeter-session-broadcast unity8-desktop-session   # to remove the 7 last dependencies
then, remove libunity-scopes1.0:amd64 manually cause dpkg --dpkg had some issues with this one so with command line:
rm -r /usr/share/doc/libunity-scopes*
rm /var/lib/dpkg/info/libunity-scopes*
rm /usr/share/apport/package-hooks/libunity-scopes1.0.py
rm /var/crash/libunity-scopes*
then you can use:
dpkg --purge libunity-scopes1.0:amd64
apt-get install -f
apt autoremove
muru
  • 207,228
