I'm trying to recover data from a disk with multiple corrupted sectors. Damaged partition (Windows partition, sdb2) s no longer mountable (it takes a lot of time, and sometimes makes Ubuntu file explorer crash/everything get laggy), so I tried to use ddrescue to recover its data.
I formatted another disk (2 times bigger than damaged partition) as FAT (sda1) and intended to use it as a rescue disk.
I run this command :
sudo ddrescue -B -v -n --force /dev/sdb2 /dev/sda1 récupérationLog2.log
After 9 hours of intense work, the console output seems pretty nice as it mentions 953525 MiB of data rescued (on a 1TB partition):
*GNU ddrescue 1.19
About to copy 953668 MiBytes from /dev/sdb2 to /dev/sda1.
Starting positions: infile = 0 B, outfile = 0 B
Copy block size: 128 sectors Initial skip size: 128 sectors
Sector size: 512 Bytes
Press Ctrl-C to interrupt
rescued: 953525 MiB, errsize: 142 MiB, current rate: 3072 B/s
ipos: 904228 MiB, errors: 513, average rate: 29903 KiB/s
opos: 904228 MiB, run time: 9.07 h, successful read: 0 s ago
Finished*
Everything seems pretty good, but when I mount the rescue partition, sda1, it seems there is no file at all. Everything is empty. Of course it tried to list hidden files with ls -a, but there's nothing there.
That's the second times I get what seems to be a pretty successful recovery without getting any output files. Is there anything I did wrong or anything else to try?
Excerpt of logFile
# Rescue Logfile. Created by GNU ddrescue version 1.19
# Command line: ddrescue -B -v -n --force /dev/sdb2 /dev/sda1 récupérationLog2.log
# Start time: 2017-04-18 09:47:59
# Current time: 2017-04-18 18:52:11
# Finished
# current_pos current_status
0xDCC247D000 +
# pos size status
0x00000000 0x0160C000 +
0x0160C000 0x00000200 -
0x0160C200 0x02B5FC00 /
0x0416BE00 0x00000200 -
0x0416C000 0x14B94000 +
0x18D00000 0x00000200 -
0x18D00200 0x003FFC00 /
0x190FFE00 0x00000200 -
0x19100000 0x4F570000 +
0x68670000 0x00000200 -
0x68670200 0x00005C00 /
0x68675E00 0x00000200 -
0x68676000 0x00094000 +
0x6870A000 0x00000200 -
0x6870A200 0x00001C00 /
0x6870BE00 0x00000200 -
0x6870C000 0x008E0000 +
0x68FEC000 0x00000200 -
0x68FEC200 0x00002C00 /
0x68FEEE00 0x00000200 -
0x68FEF000 0x0000A000 +
0x68FF9000 0x00000200 -
0x68FF9200 0x00006C00 /
0x68FFFE00 0x00000200 -
I had to add the argument --force cause every time I tried to use ddrescue it said it could not start due to ouputlog file already exists even if I tried a different, non-existent file name each time.
