I have a ubuntu 16.04, windows 10 asus dual boot.
I saw a similar (but not the same) question posted to this one at this link: Intel Centrino Wireless-N 2230 won't connect, keeps asking for password.
My wireless connects but no data is transferred, I can't load google, etc. I typed in:
lspci -knn | grep Net -A3
And received:
03:00.0 Network controller [0280]: Qualcomm Atheros QCA9565  / AR9565 Wireless Network Adapter [168c:0036] rev(01)
Subsystem: Lite-On Communications Inc QCA9565 / AR9565 Wireless Network Adapter [11ad:0662]
Kernel driver in use: ath9k
Kernel modules : ath9k
I tried the fixes suggested, but I do not have the /etc/modprobe.d/iwlwifi-opt.conf file, only a /etc/modprobe.d/iwlwifi.conf file. I tried to adapt for atheros vs. intel, but I lack the proper know how.
What should my next steps be?
Thanks.
EDIT 1: I entered the following command as suggested by user nadav mavor:
sudo ifconfig -a ping 8.8.8.8
I received:
SIOCSIFADDR: No such device
ping: Error while getting interface flags: No such device
Edit 2: Corrected the command inputs. I entered:
sudo ifconfig
and received:
enp2s0 Link encap:Ethernet HWaddr 08:62:66:1d:ac
       UP broadcast multicast MTU: 1500 metric:1
       RX packets:0 errors:0 dropped:0 overruns:0 frame:0
       TX packets:0 errors:0 dropped:0 overruns:0 frame:0
       collisions: 0 txqueuelen:1000
       RX bytes:0 (0.0B) TX bytes:0 (0.0B)
lo     Link encap:local loopback\
       inet addr:127.0.0.1 Mask:255.0.0.0
       inet6 addr:1/128 Scope:Host
       UP Loopback Running MTU: 65536 metric:1
       RX packets:12 errors:0 dropped:0 overruns:0 frame:0
       TX packets:12 errors:0 dropped:0 overruns:0 frame:0
       RX bytes:632 (632.0B) TX bytes:632 (632.0B)
wlp3s0 Link encap:Ethernet HWaddr 18:cf:5e:d2:63:df
       inet addr:10.121.131.95 Bcast:10.121.143.255 Mask:255.255.240.0
       inet6 addr:fe80::cae7:ed2b:584a:84cb/64 Scope:Link
       UP Loopback Running MTU: 1500 metric:1
       RX packets:6002 errors:0 dropped:0 overruns:0 frame:0
       TX packets:3663 errors:0 dropped:0 overruns:0 frame:0
       RX bytes: 8134153 (8.1MB) TX bytes: 421410 (421.4KB)
entered sudo ping -c2 8.8.8.8 and received:
PING 8.8.8.8 (8.8.8.8) 56(84) byts of data
64 bytes from 8.8.8.8: icmp_seq=1 ttl=59 times=38.4ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=59 times=13.9ms
--8.8.8.8 ping statistics
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 13.998/26.201/38.405/12.204 ms
I entered sudo iwconfig and received:
wlp3s0    IEEE 802.11bgn ESSID "internetname"
          mode:managed frequency: 2.412 GHZ Access Point: 84:D4:7e:01:A0
          bit rate=65Mb/s Tx-Power = 17dBm
          retry short limit:7 RTS thr:off Fragment thr:off
          Encryption key:on
          power management:off
          Link Quality=50/70 Signal level=-60dBm
          Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
          Tx excessive retries:0   invalid misc:0 Missed beacon:0
enp2s0    no wirless extensions
lo        no wireless extensions
Edit 3: For running sudo cat /run/resolvconf/resolv.con, I receive:
 # Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
 #     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
 nameserver 127.0.1.1
 search "educationalinstitution".edu
Eliah Kagan
  • 119,640
EMP
  • 103
ok its clear that you didn't get DNC from your network the fast and easy was of fix will be to just add by heand :
1) as root edit /etc/resolvconf/resolv.conf.d/base and put
nameserver 10.11.12.83
nameserver 208.67.222.222
it will add 2 name servers to your system (google one and openDNS one )
2) restart your network "/etc/init.d/networking restart"
3) test the new DNS "ping -c2 google.com"
new your system can work and your next step is to talk to your network manager to see why your system do not geting the proper DNS config
