12
I'm getting this whenever I go to a new Web page starting a new tab in Chrome
"your connection was interrupted; a network change was detected"
then it proceeds to the page, although often enough it doesn't properly load all of the page.
I've recently upgraded from 16.10 to 17.04 and my Chrome is 57.0.2987.133 (64-bit).
In general, any Chrome browser move (submit, new page) seems hesitant, gets stuck/freezes. Didn't have this problem before the upgrade.
BTW, I found this discussion, but not sure what to do in Ubuntu.
147pm
  • 2,185
8 Answers8
10
Disabling IPv6 seems to have durably resolved the symptoms for me.
(I suspected that IPv6 might be relevant based on this old post https://productforums.google.com/forum/#!topic/chrome/P7qEIWA1__M.)
To check if IPv6 is active, go to the NM panel (wifi symbol near clock) and select Connection Information, like this:
If IPv6 is already ignored or inactive, this answer doesn't apply to you. If IPv6 is active, then disable ("ignore") it in System Settings > Network like so:
Please comment with success/failure so that we can confirm this workaround.
I suspect other network services were unaffected because they use IPv4.
Original post:
I have exactly the same symptoms, browser version, and upgrade path. Firefox does not exhibit similar symptoms. Furthermore, I routinely access other network services (e.g., pypi, mvnrepository) during builds and have no issues there.
The chrome symptoms seem to vary widely. The most frequent symptom (as the OP noted) is the "Your connection was interrupted" error. Other symptoms include missing graphics, incompletely styled pages, and empty content (presumably ajax failures).
That is, the issue is specific to chrome on 17.10, and it affects multiple content types.
Reece
  • 320
I had this issue too but in my case it was a Docker container going up and down every 10 seconds that made everything behave in a very weird fashion.
Also for the fix above, in case it is IPv6, below is a pure CLI guide.
A pure command line fix instead of clicking in the UI would be:
nmcli device modify wlan0 ipv6.method ignore
Or if you want to do it per connection:
nmcli con modify $CONNECTION_NAME ipv6.method ignore
In my case too, it was a Docker issue which was possibly interfering with the internet.
  1. Go to Terminal : (ctrl + alt + T)
  2. Login as sudo user (You need to have admin rights)
  3. Check for running containers : docker ps -a
  4. Remove the containers : docker rm -f <containerID>
Gryu
  • 8,002
  • 37
  • 53
I have the same problem and its extremely annoying, look in your /var/log/syslog.
I noticed an overwhelming amount of the same lines being repeated in my log:
avahi-daemon[*]: Registering new address record for My IPV6 Address Here and:
avahi-daemon[*]: Withdrawing address record for My IPV6 Address Here.
It might be normal for some things to repeat in a log but my ipv6 was changing a lot, I mean at least 10 or more times in less than a minute.
Solution.. sort of...
If you have the same lines repeating in your syslog( you can check with this command:
$ grep "avahi-daemon" /var/log/syslog)
The only temporary solution I have found is to disable IPv6. I used this tutorial for 16.04, it still works for 17.04 though: http://www.neuraldump.com/2016/11/how-to-disable-ipv6-in-ubuntu-16-04-xenial-xerus/
p.s. I thought that avahi-daemon was the cause of IPv6 resetting but its not it is just noticing it happen, avahi-daemon deals with mdns. This should save you a good 10-20 min of useless research into the avahi-daemon.
This is just a band-aid it doesn't fix the underlying problem, at some point or another ipv6 will be needed, if I find a TRUE solution I will update this post.
Good luck!
I have this issue occasionally, but it's not limited to 17.10:
Version 61.0.3163.100 (Official Build) Built on Ubuntu , running on Ubuntu 16.04 (64-bit)
Disabling IPV6 does seem to eliminate it.
It's hard to know for certain what the causes of the issue might be but based on https://productforums.google.com/forum/#!topic/chrome/P7qEIWA1__M you might simply be able to change your IPv6 privacy settings to Disabled to stop this happening.
See the highlighted box in this image to see where to change it.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
In my case, one of my docker-compose services was restarting rapidly due to incorrect environment variables. I corrected the wrong environment variable, and everything got okay.
So, if you have a running Docker container on your system, please check it to ensure everything is OK.
I solved the problem by permanently disabling IPv6, take a look at How to disable IPv6 in Ubuntu 14.04?
It worked like a charm for me!
