I am very curious about the new Anbox emulator for running Android apps on PC. Unfortunately I can't make it work on my PC.
After having installed via snap there is a new entry in the Gnome menu list. When I use it, nothing happens. I then tried to start it via terminal with the result, but at least some output.
Starting the session manager seems to work. This step was recommended in a previous question close to mine (Anbox isn't starting up on my PC at all).
anbox session-manager
Session manager can be started without error or any message. It just seems to run an Android instance fine, which I even can access with adb shell.
Anbox demon ("anboxd") and Init-Script ("anbox-init.sh") are running, too (checked with "ps -A").
But when I try to start Anbox Launcher, the Launcher cannot be started:
anbox launch
[WW 2017-04-14 17:46:12] [launch.cpp:115@operator()] Stop waiting as we're already waiting for too long. Something is wrong
[WW 2017-04-14 17:46:12] [launch.cpp:116@operator()] with your setup and the container may have failed to boot.
Same result when I start the Anbox icon from launcher (here I started it via shell):
anbox launch --package=org.anbox.appmgr
[WW 2017-07-05 15:26:54] [launch.cpp:194@operator()] Stopped waiting as we've already waited for too long. Something
[WW 2017-07-05 15:26:54] [launch.cpp:195@operator()] is wrong with your setup or the container has failed to boot.
[WW 2017-07-05 15:26:54] [launch.cpp:196@operator()] If you think you found a bug please don't hesitate to file on
[WW 2017-07-05 15:26:54] [launch.cpp:197@operator()] at https://github.com/anbox/anbox/issues/new
Any ideas? As you can see, the above mentioned other response does not work.. Thank you in advance! Spectas
PS: some system infos:
anbox system-info
version: 0.1.0
os:
  version: 16
  snap-based: true
kernel:
  version: Linux version 4.4.0-53-generic (buildd@lcy01-28) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #74-Ubuntu SMP Fri Dec 2 15:59:10 UTC 2016
  binder: true
  ashmem: true
graphics:
  egl:
    vendor: Mesa Project
    version: 1.5 (DRI2)
    extensions:
      - EGL_CHROMIUM_sync_control
      - EGL_EXT_create_context_robustness
      - EGL_EXT_image_dma_buf_import
      - EGL_KHR_cl_event2
      - EGL_KHR_create_context
      - EGL_KHR_fence_sync
      - EGL_KHR_get_all_proc_addresses
      - EGL_KHR_gl_colorspace
      - EGL_KHR_gl_renderbuffer_image
      - EGL_KHR_gl_texture_2D_image
      - EGL_KHR_gl_texture_3D_image
      - EGL_KHR_gl_texture_cubemap_image
      - EGL_KHR_image
      - EGL_KHR_image_base
      - EGL_KHR_image_pixmap
      - EGL_KHR_reusable_sync
      - EGL_KHR_surfaceless_context
      - EGL_KHR_wait_sync
      - EGL_MESA_configless_context
      - EGL_MESA_drm_image
      - EGL_MESA_image_dma_buf_export
      - EGL_NOK_swap_region
      - EGL_NOK_texture_from_pixmap
      - EGL_NV_post_sub_buffer
      - EGL_WL_bind_wayland_display
  gles2:
    vendor: X.Org
    vendor: OpenGL ES-CM 1.1 Mesa 12.0.6
    extensions:
      - GL_EXT_blend_minmax
      - GL_EXT_multi_draw_arrays
      - GL_EXT_texture_filter_anisotropic
      - GL_EXT_texture_lod_bias
      - GL_OES_byte_coordinates
      - GL_OES_fixed_point
      - GL_OES_stencil_wrap
      - GL_OES_compressed_paletted_texture
      - GL_OES_query_matrix
      - GL_OES_read_format
      - GL_OES_single_precision
      - GL_OES_draw_texture
      - GL_OES_point_size_array
      - GL_OES_point_sprite
      - GL_EXT_texture_format_BGRA8888
      - GL_OES_compressed_ETC1_RGB8_texture
      - GL_OES_depth24
      - GL_OES_element_index_uint
      - GL_OES_fbo_render_mipmap
      - GL_OES_framebuffer_object
      - GL_OES_mapbuffer
      - GL_OES_rgb8_rgba8
      - GL_OES_stencil8
      - GL_OES_texture_env_crossbar
      - GL_OES_texture_mirrored_repeat
      - GL_OES_texture_npot
      - GL_OES_EGL_image
      - GL_OES_packed_depth_stencil
      - GL_OES_texture_cube_map
      - GL_APPLE_texture_max_level
      - GL_EXT_discard_framebuffer
      - GL_EXT_read_format_bgra
      - GL_OES_blend_equation_separate
      - GL_OES_blend_func_separate
      - GL_OES_blend_subtract
      - GL_OES_EGL_image_external
      - GL_OES_EGL_sync
      - GL_OES_vertex_array_object
      - GL_EXT_map_buffer_range
      - GL_KHR_debug
      - GL_OES_surfaceless_context
      - GL_EXT_polygon_offset_clamp
Spectas
  • 31
This answer was originally posted here by Brittany
first run session manager by entering this command
and then click on the Anbox icon from launcher
Better way would be to add this service inside Startup Applications
to do that open Startup Applications > Add > in command write anbox session-manager
and you'd be able to use Anbox without running that command on every boot or keeping a minimised terminal windows.
