I updated my Lubuntu 16.04 to 17.04 and it is now not connecting to my WiFi. It is detecting the signal, but doesn't want to connect. I deleted the connection and then tried to reconnect to the network but it has not helped.
Any ideas?
See below for info:
*-network
       description: Ethernet interface
       product: 82567LM-3 Gigabit Network Connection
       vendor: Intel Corporation
       physical id: 19
       bus info: pci@0000:00:19.0
       logical name: enp0s25
       version: 02
       serial: 00:26:55:46:a4:53
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.4-3 ip=192.168.0.16 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       resources: irq:30 memory:f0500000-f051ffff memory:f0525000-f0525fff ioport:1100(size=32)
  *-network
       description: Wireless interface
       physical id: 1
       bus info: usb@1:5
       logical name: wlx74da388862b7
       serial: be:1b:f1:30:ab:b5
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8xxxu driverversion=4.10.0-19-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11
and this:
Bus 001 Device 002: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
The Wireless Info Script result can be found here: http://paste.ubuntu.com/24395115/
Thanks in advance!
Jay P
  • 91
Miraculously, a user from omgubuntu.co.uk had written a comment in one of their articles announcing the release of 17.04 that fixed this issue. The comment is as follows:
wifi and networkmanager
The new NetworkManager release 1.4.0 adds new features to change the current MAC address of your Ethernet or Wi-Fi card (spoofing/cloning). As a debian "sid" user i understand that being on bleeding edge, sometimes new features and configs can be Incompatible with my machine hardware!!! Now being a ubuntu user i can see that ubuntu is losing his "user friendly" name and no more care for desktop users! This was an unacceptable default config on Ubuntu's best days! Ubuntu haters and criticists must be happy now!
fix it
edit the /etc/NetworkManager/NetworkManager.conf file
And add:
[device] wifi.scan-rand-mac-address=no
Restart the networkmanager service and use your wireless connection :)"
I found that applying his fix by opening a Terminal and typing "sudo gedit /etc/NetworkManager/NetworkManager.conf", adding the text he described, then rebooting my machine fixed the issue.
That being said, this default behavior is still a major bug and breaks functionality of wi-fi hardware for users, and definitely needs to be looked at. Thanks for your time!
terdon
  • 104,119
