I recently bought new system Lenovo G41-35 and installed Ubuntu 16.04 LTS in it.
My ram is of 8GB but due to some reason it shows only 3.3 GiB in the Details.
How I can use the 8GB Ram in my ubuntu system.
See complete information:
Below are some commands with output:
free -m
Output:
total        used        free      shared  buff/cache   available
Mem:           3354        1080         757          51        1515        1922
Swap:         24412           0       24412
sudo lshw -class memory
Output:
*-firmware
       description: BIOS
       vendor: Lenovo
       physical id: 0
       version: C3CN54WW
       date: 11/18/2015
       capacity: 8128KiB
       capabilities: pci upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer int10video pc98 acpi usb biosbootspecification netboot
  *-cache:0
       description: L1 cache
       physical id: 28
       slot: L1 Cache
       capacity: 256KiB
       clock: 1GHz (1.0ns)
       capabilities: pipeline-burst internal write-back unified
       configuration: level=1
  *-cache:1
       description: L2 cache
       physical id: 29
       slot: L2 Cache
       capacity: 2MiB
       clock: 1GHz (1.0ns)
       configuration: level=2
  *-memory
       description: System Memory
       physical id: 2a
       slot: System board or motherboard
     *-bank:0
          description: SODIMM DDR3 Synchronous 1333 MHz (0.8 ns)
          product: 9905417-075.A00G
          vendor: Kingston
          physical id: 0
          serial: 2C2602BF
          slot: DIMM 0
          width: 64 bits
          clock: 1333MHz (0.8ns)
     *-bank:1
          description: SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
          product: EBJ40UG8EFU0-GN-F
          vendor: Elpida
          physical id: 1
          serial: 95CB18FD
          slot: DIMM 1
          width: 64 bits
          clock: 1600MHz (0.6ns)
uname -a
Output:
Linux muhammad-mohsin 4.8.0-36-generic #36~16.04.1-Ubuntu SMP Sun Feb 5
09:39:57 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
uname -m
Output:
x86_64
sudo lshw | grep -m 1 -A 25 "*-memory"
Output:
*-memory
      physical id: 2a
    *-bank:0
         vendor: Kingston
         physical id: 0
         serial: 2C2602BF
         slot: DIMM 0
         width: 64 bits
    *-bank:1
         vendor: Elpida
         physical id: 1
         serial: 95CB18FD
         slot: DIMM 1
         width: 64 bits
 *-pci:0
sudo lshw -short -C memory
Output:
H/W path               Device           Class          Description
/0/0                                    memory         128KiB BIOS
/0/27/28                                memory         256KiB L1 cache
/0/27/29                                memory         2MiB L2 cache
/0/2a                                   memory         8GiB System Memory
/0/2a/0                                 memory         4GiB SODIMM DDR3 Synchronous 1333 MHz (0.8 ns)
/0/2a/1                                 memory         4GiB SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
LearningROR
  • 143
