15
I tried to install using PPA and also by downloading xampp app from apachefriends.org but all in vain. How can I install xampp without any error? Someone suggest a way.
bash: ./xampp-linux-x64-5.6.20-0-installer.run: cannot execute binary file: Exec format error
This is the error i face while I try to install
Foxie
  • 551
Sarath
  • 365
If you are running into specific errors, it would be useful to have them in your post to help us diagnose the problem. But to install xampp, it should be as easy as:
wget https://www.apachefriends.org/xampp-files/5.6.20/xampp-linux-x64-5.6.20-0-installer.run
sudo su
chmod +x xampp-linux-x64-5.6.20-0-installer.run
Taken from http://www.ubuntumaniac.com/2016/04/install-xampp-5620-on-ubuntu-1604.html.
Foxie
  • 551
If you want to do a fresh installation, follow this
Note : LAMPP is the Linux specific version of XAMPP.
  1. Download LAMPP-Server using this command
    $sudo apt-get install lamp-server^
  2. Goto https://www.apachefriends.org/download.html and download the version of LAMPP software that you want for Linux (Ubuntu).
  3. Open your Terminal and locate the file (by default it downloads into the Downloads folder)
    cd Downloads
  4. Execute this command
    sudo chmod +x xampp-linux-x64-7.1.7-0-installer.run
    Note : The version of XAMPP you'll download might be different, so change the version in this command accordingly.
    You'll be asked for your system's password
  5. Now go into SuperUser mode
    sudo su
  6. Run the installer, but don't close the Terminal.
    ./xampp-linux-x64-7.1.7-0-installer.run
    Note: Again change the version for executing this command.
    A dialog box will open, if you get an error, ignore it. In the dialog box, click next(for each step) and move through the process of installation. Once XAMPP is installed, click finish.
  7. Go back to your Terminal and change the directory
    cd /opt/lampp
  8. To set a password, type
    ./lampp security
    Press y(Enter) and enter a new password and re-enter this password again to confirm
  9. Start XAMPP
    ./xampp start
  10. Type exit(Enter) to exit the SuperUser
  11. To start LAMPP, execute this command
    sudo /opt/lampp/lampp start
  12. To stop LAMPP, execute this command
    sudo /opt/lampp/lampp stop
Prajwal
  • 616
By default Ubuntu does not allow files to be executed, thus you need to enable it.
1) Select the .run file and go to its properties.
2) Go To permissions Tab and enable 'is executable' option
3) Now if you have root privilege you'll be able to double click on it and complete the installation process. Or do sudo ./xampp-linux-x64-7.2.2-0-installer.run making sure you have the correct version.
Samy
