I'm trying to install QGIS on Ubuntu 14.04 LTS. I ran the following,
sudo add-apt-repository ppa:ubuntugis/ppa
sudo apt-get update
sudo apt-get install qgis
But I get the following message,
  qgis : Depends: gdal-abi-2-1-0
    Depends: libgdal20 (>= 2.0.1) but it is not going to be installed
    Depends: libgeos-c1v5 (>= 3.4.2) but it is not going to be installed
    Depends: libqgis-analysis2.14.3 (>= 2.14.0) but it is not going to be installed
    Depends: libqgis-app2.14.3 (>= 2.14.0) but it is not going to be installed
    Depends: libqgis-core2.14.3 (>= 2.14.3) but it is not going to be installed
    Depends: libqgis-gui2.14.3 (>= 2.14.0) but it is not going to be installed
    Depends: libqgis-networkanalysis2.14.3 (>= 2.0.1) but it is not going to be installed
    Depends: python-qgis (= 2.14.3+dfsg-2~trusty1build1) but it is not going to be installed
    Depends: qgis-providers (= 2.14.3+dfsg-2~trusty1build1) but it is not going to be installed
    Depends: qgis-common (= 2.14.3+dfsg-2~trusty1build1) but 1:2.18.6+24xenial is to be installed
    Recommends: qgis-plugin-grass but it is not going to be installed
    Recommends: qgis-provider-grass but it is not going to be installed
    Recommends: qgis-plugin-globe but it is not going to be installed
I'm still a Linux/Ubuntu noob and am not sure how to move forward.
user13317
  • 139
This post was a lot of help! I just needed to modify a couple of things to bring the answer up to date.
In Step 2 I needed to add the following to the last line of the /etc/apt/sources.list,
deb http://qgis.org/debian trusty main
deb-src http://qgis.org/debian trusty main
Then execute the following two commands to add the public key for QGIS,
gpg --keyserver keyserver.ubuntu.com --recv DD45F6C3
gpg --export --armor DD45F6C3 | sudo apt-key add -
Update repository,
sudo apt-get update
Simply follow the rest of the post and it should work, at least it worked for me!
user13317
  • 139
