I am trying to install a program on my Linux. When running: sudo apt-get install nams I keep getting:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
         linux-image-extra-4.4.0-71-generic :
          Depends: linux-image-4.4.0-71-generic but it is not going to be installed
         linux-image-generic :
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I tried to fix it doing: sudo apt-get -f install
karel
  • 122,292
  • 133
  • 301
  • 332
Florin
  • 61
Seems like you have double sources in your plist.
To fix this issue:
sudo apt-get clean
sudo apt-get autoclean
Then run :
sudo dpkg --configure -a
Also you can comment out the double source in the sources.list
If you need help, print the output of the sources.list and show me.
Like this :
cat /etc/apt/sources.list > /home/user/sources.txt
If you wanne do it yourself just use nano or vim :
sudo nano /etc/apt/sources.list
An0n
  • 2,225
