34
It's a rather simple problem, but I can't find the solution:
The menu bar in Kate (File, Edit, ...) has disappeared, and I tried looking up in the katerc file. How can I restore it?
user258532
  • 1,298
Had the same problem... and CTRL+M also solved it for me. I never actively hide my menus, so arriving at this solution was not intuitive. No idea what (bug?) caused the sudden disappearance of the menu.
mook765
  • 18,644
protonic
  • 626
Came across this same bug this week. Unfortunately I had [Ctrl] + [M] mapped to something else. My solution was to find the file .katerc (in ~/.config on my Kubuntu machine), and invoked (courtesy of http://askubuntu.com/a/1274762/1002900)
find ./ -type f -exec sed -i 's/MenuBar=Disabled/MenuBar=Enabled/g' {} \;
find ./ -type f -exec sed -i 's/Show Menu Bar=false/Show Menu Bar=true/g' {} \;
to replace
MenuBar=Disabled and Show Menu Bar=false
with
MenuBar=Enabled and Show Menu Bar=true
I closed all my open kate windows, restarted, and my menu bar was back.
Fergal
  • 161
Three things are required to get your menus back under the title bar.
  1. cd into your .config folder and execute:
  2. In KDE settings > Window management > Menu tab > remove burger applications menu from title bar in both active and inactive windows
  3. In KDE settings > Startup > Services > disable the menu daemon
Plus if you want your top menus in kate, hit ctrl+m twice.
Simon Sudler
  • 4,111
Dave
I solved the problem by:
  • looking for katerc with find * | grep katerc, and deleted it
  • sudo apt purge kate
  • sudo apt install kate
user258532
  • 1,298
