I have a desktop PC and a notebook in the same network. Each of them is running Ubuntu 11.10. I shared a folder on my notebook which I somehow can not access by my PC.
Here is what I did so far:
On the notebook I right clicked on my home folder and went to
Properties -> Share
where I marked Share this folder and Allow others to create and delete files in this folder. It asked me for installing some services. They failed. So I did manually sudo apt-get install samba. Worked fine. Now I went to my PC an opened my home folder. Above in the menu I selected GO->Network. There I pressed CTRL+L and entered the local ip address from my notebook. But somehow it can't find it.
Is there more configuration, that I have to do?
I appreciate every help, thanks!
PS: Sometimes it says
Error: Failed to retrieve share list from server
Please select another viewer and try again.
I refer to this picture in one of the comments below. It is not directly related to the formulation of my initial question but to a solution presented below by @lumbric in the comments.
Flyk
  • 1,480
  • 18
  • 24
Aufwind
  • 1,833
Re-creating the share on your notebook (as you first tried to do) after installing samba may solve your problem. Already happened to me. Tell me if this works to update my answer.
Using sshfs to share folders:
If you want to share folders between Ubuntu computers, may I suggest to use a native Linux solution ? Samba re-implements windows protocols and i always ended up having issues with the samba configuration. On the other hand I found sshfs much easier to use. Assuming you have sshfs installed and you're a user of the fuse group, just do the following:
mkdir ~/shared_folder
sshfs <user>@<ip>:<shared_folder_path> /home/$USER/shared_folder
Then check it works and do your stuff:
cd ~/shared_folder
ls
nautilus .
etc.
To unmount:
fusermount -u ~/shared_folder
Adding an entry to /etc/fstab:
Some people prefer to add this line at the end of the /etc/fstab file:
sshfs#<user>@<ip>:<shared_folder_path> <mount_point> fuse defaults,user,idmap=user,noauto 0 0
By doing so, you'll be able to mount the folder with mount ~/shared_folder. Still unmount with fusermount.
I'm not usually using this method as i configured my key to browse my bash history so that just typing sshf+ gives me all my previous sshfs mounts. Also, I don't need to do system-wide changes.
Maxime R.
  • 3,920
CTRL+L in Nautilus (that's the name of Ubuntu's default file browser) was a good start! But you have to use the correct network protcoll which is smb when using Samba. So you have to enter:
smb://127.0.0.1/
(of course replace the IP address)
This might be quite a serious usuability bug in Ubuntu. If you just click on "network" it never finds any computer in your network.
Additional tipps
I'm not sure wether SMB is the best joice for a home network if both machines are running Ubuntu. Samba is primarily used in order share files with windows computers. But I haven't any better suggestions. sFTP and SSH is good but slow. NFS is lacking some important features as far as I remember. FTP might be a joice.
PS: Btw note that STRG is german and english speaking users might not understand that this is the CTRL key... ;)
lumbric
  • 4,129
