I have gnome-tweak-tool install and use it regulary. I cannot however install the gnome-shell-extensions-user-theme to change the shell.
I already have the ppa but when it put
sudo apt-get install gnome-shell-extensions-user-theme
into the terminal i get this output.
dvorak@dvorak-g51vx:~$ sudo apt-get install gnome-shell-extensions-user-theme
[sudo] password for dvorak:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an
impossible situation or if you are using the unstable distribution that some
required packages have not yet been created or been moved out of Incoming.
gnome-shell-extensions-user-theme : Depends: gnome-shell-extensions-common
but it is not going to be installed
Can anyone elaborate on what I am doing wrong? I have tried to both install and remove both the unmet dependencies with the same error.
Jorge Castro
  • 73,717
I was having a similar problem. gnome-shell-extensions-user-theme is 3.2 whereas the shell is 3.4. Shell extensions seem to be handled by installing from https://extensions.gnome.org/ rather than yourself via package manager.
Lasher
  • 477
Try ;
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install -f
Then try installing gnome-shell-extensions-user-theme again
If you get any error message with those first 3 commands, post back or use pastebin
Panther
  • 104,528
Installing from here: https://extensions.gnome.org/extension/19/user-themes/ ended up working for me. Had the exact same error msg.
Notes ubuntu precise -> gnome3 shell 64bit
AKnox
  • 111
